Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Confusing CC test results with Taylor K-2006 test kit
    Apr 2017
    Pleasant View, TN
    13
    When I run the CC test, when I add R-0003, the water turns yellow instead of pink. This is not addressed anywhere. I added the R-0871 which seems to be a waste because I stopped at 35 drops on the 10ml test with no change in color. Remained yellow. I am using a fresh sample in a clean (with pool water) tube. I have a Taylor K-2006 test kit, following the directions to a T. I am SLAMing my water to rid of algae. My results for everything else follows:
    FC= 66ppm
    CC= ??
    Ph= 7.0
    Alkalinity= 70ppm
    Calcium= 250ppm
    CYa= 50ppm
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Confusing CC test results with Taylor K-2006 test kit
    Welcome to the forum!
    I'm not entirely sure, but my first assumption would be because your FC is so high. Why are you dosed at 66 PPM FC?
    Essential Links:
    Apr 2017
    Pleasant View, TN
    13
    Put in the amount of turbo shock recommended by pool company. Received my test kit hours after I added the shock.
    JoyfulNoise's Avatar
    May 2015
    14,077
    Quote Originally Posted by Schuess60 View Post
    Turbo Shock (by Pool Life I am assuming) is calcium hypochlorite. It takes 7lbs of 65% cal hypo per 10,000 gallons of pool water to raise the FC from 0 to 66ppm (I don't know your pool volume so you may have added less). That is a HUGE amount of FC and not something TFP would ever recommend because it is a waste of chlorine and possibly damaging to equipment and pool liners.
    It is possible at really high FC and with enough chloramines in the water that the potassium iodide solution (R-0003) could create elemental iodine (I2) instead of the triiodide anion (I3-) needed to oxidize the DPD and turn it back into pink. Elemental iodine would appear yellow in the water. Another possibility is compromised reagent - does the bottle of R-0003 appear yellow at all?
    You need to let your FC come down a bit before you can really test anything with any kind of accuracy. I'm surprised you could get any of the other tests to work with that much chlorine in the water sample.
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Ok,
    Yea, I would just let the FC come down before you worry about that test anymore. From here, trust your own results once you're comfortable with all the test and ask questions here first if your are unsure of anything.
    Essential Links:
    Apr 2017
    Pleasant View, TN
    13
    You are correct. I put 4 scoops of PoolLife Turbo Shock which is what brought the FC up that high. I have a 21,000 gallon inground pool with a vinyl liner. Water is good color but very cloudy. Today's test results are as follows:
    FC= 10ppm
    CC= 0
    Ph= 7.0
    Alkalinity = 70ppm
    Calcium = 210ppm
    CYa = 40ppm
    The reason I have CC at 0 is again it turned yellow when I added the R-0003 albeit much lighter than the other day. The R-0003 regent appears clear.
    Apr 2017
    Pleasant View, TN
    13
    Water is remaining cloudy and I don't know why. Had same problem last year when opening and finally changed out my sand which fixed the problem.
    Apr 2017
    Pleasant View, TN
    13
    40,848
    Let's just confirm you actually used R0003. Would not be the first time the wrong bottle was used
    Apr 2017
    Pleasant View, TN
    13
    Yes. R-0003.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    The water is cloudy because your FC is 10 when the CYA is 50. Shock level is 20 FC. You've killed a lot of algae, but not all. You need to keep the FC level up until you pass all three tests as outlined in the SLAM directions.
    Also, Cal-hypo will sometimes cloud water. Another reason to use bleach.
    Apr 2017
    Pleasant View, TN
    13
    Any ideas on why the CC test turns yellow as opposed to pink?
    40,848
    How old is the test kit? Where did you get it? Has it ever worked correctly?
    Apr 2017
    Pleasant View, TN
    13
    Test kit was purchased a week ago. No, the R0003 has always shown yellow. Purchased on Amazon by VM Innovations.
    40,848
    Picture of the yellow test?
    Only thing that typically turns water yellow is r0600 for the OTO test. I am thinking bad reagent. You can likely get a bottle of r0003 locally pretty cheap to try.
    Feb 2017
    Dahlonega, Georgia
    105
    The Taylor reagent bottles have a batch number and expiration date. You could call Taylor to see what they say about it.
    Coleman Lay-Z-Spa inflatable spa (by Bestway), 210-230 gal, installed in garage, currently using the dichlor/bleach method, custom test kit which is essentially a Taylor K-2006 with Taylor K-1004 comparator block for pH, Speed Stir
    Apr 2017
    Pleasant View, TN
    13
    Wouldn't even know where to look. Pool companies only carry complete kits in this area.
    40,848
    Really? The local store I go to has a rack of individual reagents right at the desk.
    Apr 2017
    Pleasant View, TN
    13
    I live in rural Tennessee. Please...
  20. Back To Top    #20
    40,848
    Ah bummer.
    What happens if you put the r0003 directly into the test water? Can you post a picture?
