Results 1 to 16 of 16
Thread: Skimmer filter function
    steveb21's Avatar
    Mar 2017
    United Kingdom, England.
    198
    How is the skimmer supposed to function?
    Is the piece in middle supposed to move up and down? Or should it be fixed?
    Mine bounces up and down, it's ok when it's down but when it goes up it pushes the water in the opp direction for a second or so.
    Outdoor Inground Heated Concrete Tiled Pool - 25ft x 12ft and 3ft 4" to 6ft 6" deep - 45k Litre Water Capacity
    Valve - Hayward Vari-flo 711-13 ------ Pump - Sta-Rite 5P1R
    Filter - Hayward S244T -------- Test Kit - Taylor K2006C
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Skimmer filter function
    I think we're going to need a pic or two. The majority of skimmers have a door on the pool side, that floats at the water level. It sounds like you have something a little different.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    steveb21's Avatar
    Mar 2017
    198
    Here you go:
    The left part fits flush down, the part on the right fits into it.
    video : 15 April 2017 - YouTube
    (excuse the dirt, in the middle of cleaning everything up)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Oh I remember you. Good idea with the video! I have two thoughts; either the pump is too strong or the water level isn't right, in the pool. I'm assuming that the slidey part, floats when the pump is off...
    steveb21's Avatar
    Mar 2017
    198
    Good call on the water level. If anything I think it may be too high, do you think this would cause the problem?
    it actually was working fine a few days ago, the middle piece sat a level which continually purged water through, take it that's how it should work?
    Dec 2016
    Arlington, Texas
    291
    During the slam, since your pump will be running 24/7, just pull that piece out for now
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Quote Originally Posted by steveb21 View Post
    Yes. That's how it should work. Just sit in one place; not cycle up and down like in the video. That sucking sound kinda weirded me out :P
    steveb21's Avatar
    Mar 2017
    198
    Hmmm what could be causing it then?
    My water level is approx half - in between skimmer.
    If I remove the middle piece the suction reduces by a fair amount.
    On 2 occasions the middle piece has some how got stuck at the bottom , which causes the pump to lose its prime.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Does the middle part float when the pump is off?
    steveb21's Avatar
    Mar 2017
    198
    Yep, it floats when the pump is off.
    The other piece slightly raises aswell - when pump is off.
    Dec 2016
    Arlington, Texas
    291
    Once you open main drain as well, the suction will be less. That "could" be the issue at the moment
    steveb21's Avatar
    Mar 2017
    198
    Good point, il see how it goes. Many thanks.
    Jan 2017
    Monterrey, NL, Mexico
    492
    The problem you have on the video is that the skimmer basket is not level with the
    water line. That makes the floating part stick and cycle like that. Make sure the whole
    assembly is clean with no debri and level the basket.
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    steveb21's Avatar
    Mar 2017
    198
    Opening the drain/sump did not resolve the issue with the skimmer float.
    I thought as a general rule of thumb that the water level should be approx middle of skimmer area? I will double check but the only way to make the basket level with water line is to to lower water level, im pretty sure that it will then be less than 50% of the opening?
    At times (i think when there is less water movement) it appears to work fine.
    Below videos were taken ony few mins apart.
    Not working
    https://youtu.be/CQen7sf-8mk
    Working
    https://youtu.be/0klKm-5y-20
    May 2016
    Missouri
    13
    It looks like it's getting stuck due to friction. Maybe lightly sand the surfaces to get them to slide better. I've noticed that some of the plastics get porous over time and change properties after being in the pool environment.
    steveb21's Avatar
    Mar 2017
    198
    Just to update this incase any one else has a similar issue.
    I ordered another kit.... it was identical to the one I already had BUT it came with clips which secure the collar to the middle section, this prevents the collar from rising up too much therefore preventing the loss of suction. Glad it was a simple one!
