Thread: Approximately how many gallons is my pool?
    Mar 2017
    Rocklin/CA
    20
    Ok everyone I'm just getting started here. How many gallons would y'all say is in my pool & spa?
    Measurements are:
    Kidney Shape Pool: 28ft x 18ft & 3.5ft shallow to 7ft deep end
    Round Spa: 70" across x 40" deep in the middle
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Approximately how many gallons is my pool?
    Down toward the bottom of PoolMath is volume calculator, link for PoolMath is at the top of the page.
    Mar 2017
    Rocklin/CA
    20
    Thanks!
    Mar 2017
    Naples/FL
    73
    Quote Originally Posted by STREETFIGHTER50 View Post
    Measurements are:
    A kidney is like an oval with a waist. Use 28' x 16'. For the hot tub 5.83' x 3.33'.
    14-15000 gallons. I'd use 14500. See what you get from Pool Math.
    17,250 gallon plaster pool & spa, IC40 SWCG, Cartridge Filter, CYA 70-80, Boric 50 ppm, Temp~84F, Naples, FL.
    Mar 2017
    Rocklin/CA
    20
    Thanks Naples
