Results 1 to 8 of 8
Thread: $ for 8000 gals tap water in Coppell TX?
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    Hi all,
    My cousin has to drain. CYA 100 at least. Does anyone have an idea what the replacement water will cost for 8000 gallons tap in Coppell, TX?
    Thanks!
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: $ for 8000 gals tap water in Coppell TX?
    Not much. I was shocked at how little my water bill went up filling the pool at 20k gallons. It was so long ago I can't remember how much it was though.
    triptyx's Avatar
    Apr 2016
    1,476
    Call the local water department. Explain what you're looking for and they can help you out.
    Mine said they bill in units, with it costing a certain amount of money per unit, and it would take y units to make up the number of gallons in my pool. Worked very well to approximate my cost.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,273
    P&C,
    I live in Bedford, just West of the DFW airport.
    It cost me about $50 to fill up my 17K gallon pool about three years ago.
    In Bedford anyway, if you tell them you are filling a pool, they will only charge you for the water and not for the Sewer charges...
    Aug 2016
    Riverside, CA
    378
    That is right over 1000 cf. Water is usually billed in units of 100 cf (HCF) so that is 10HCF. Check your billing statement to see the rate and verify if you have tiered billing or even penalty tiers if you're in a drought area.
    Take the billing rate in $ per HCF and multiply it by the 10HCF you'll be using.
    Aug 2016
    Riverside, CA
    378
    For me, BTW, that would be about $50 if I went into the penalty tier, otherwise about $20 so I'd plan other water use accordingly.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Make sure you call though. They won't charge you for waste water. Thats whats expensive.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Aug 2016
    Riverside, CA
    378
    Oh. Fortunately we don't have meters on the sewer here.. just a flat $30ish a month, higher in other areas.
