Results 1 to 11 of 11
Thread: Time for new SWG?
    Jul 2016
    Wesley Chapel
    34
    Time for new SWG?
    Hi guys,
    The last time my chlorine generator died it didn't register salt above areading of 2300 and stopped producing chlorine even though there was plenty of salt in the pool. I think this one is about 5 years old so I know it is getting close to having to replace it but i am not sure yet. The serial # is: 3E11209-2686626 - it is a T-Cell 15.
    I am getting very different readings between the salt level, which it says is at 3000 and the instant salinity reading, which used to read about the same as the normal salt reading, then started to display about half of what the normal reading was and now is down to 300 even though the normal reading is still 3000 before I push the diagnostic button. It still seems to produce chlorine but I am having to turn the dial up higher and higher to maintain a good level. DOes it sound like it is time to replace? IS there a test that can be done to be sure?
    Greg
    15' x 30', 13.5K Gallons, Pebble Sheen, 2 Deck Jets, Haywood 4820 DE Filter, Haywood Northstar 1.5 HP Pump, Haywood T-Cell-15, Haywood Heat Pump, Haywood Navigator Pool Vac
    Apr 2017
    Maine
    231
    Re: Time for new SWG?
    Possibly a local pool store has a Hayward cell tester. How old is this cell? Have you cleaned it?
    Jul 2016
    Wesley Chapel
    34
    Yes, I've cleaned it. It's about 5 years old so I do think it is about time but would rather be sure before buying a new one. I can try a local pool store to see - wasn't sure if there was a way to test it at home.
    Thanks.
    Apr 2017
    Maine
    231
    I'm guessing at 5 years it could possibly be on its final legs. They do make an extended life cell now. Check out pricing online.
    Jul 2016
    Wesley Chapel
    34
    Quote Originally Posted by Chemnut View Post
    So I just checked it again and the salt reading went from 3000 to 1500. Chlorine reading is at 2. Looks like it might need to be replaced
    Oct 2015
    San Diego, Ca.
    804
    These folks have one for $320.
    Hayward T-Cell15 Salt Cell, Generic Replacement Aquarite 40K w/ Cable Salt Pool | eBay
    The Ebay counter says they have sold 1,003. 30 day money back guarantee and 2 year warranty. Might be worth a try....
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Apr 2017
    Maine
    231
    That's a darn good price. Wow
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    I wonder how it lasts compared to an OEM? Funny how some of the reviews say it's a name brand.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    There are lots of horror stories about generic cells, especially from eBay sellers. I would steer clear.
    Oct 2015
    San Diego, Ca.
    804
    Quote Originally Posted by pooldv View Post
    In this case, Pool Supply World (15,000 positive responses) is a very reputable vendor.
    Jun 2011
    Long Beach, CA
    2,891
    You don't have to go through ebay to get that deal, they list it on their store website.
    With their full two year replacement warranty it makes it enticing for those who want to spend as little as they can to get the SWG up and running.
    The questions would be how do they honor the warranty and how long do these cells last? I have a local authorized Hayward shop near me that I can take a bad cell in, they test it and replace it right then if it is bad.
