Thread: Recycling water from winter
    Apr 2017
    Sudbury Ontario Canada
    1
    Thoughts about recycling winter water that has accumulated. Problem I'm facing is it's pretty nasty and I'm concerned it will take a lot more work to clean up than just bringing in new water.
    Donldson's Avatar
    NW Ohio
    3,217
    Re: Recycling water from winter
    Yes, but whether you should depends on the alternatives. Is your water expensive? Does it have metals that you would rather keep out of your pool? These are questions you have to consider because you will need to use additional chlorine to kill whatever is in the cover water, which may be more costly or more trouble than bringing in clean water.
    And let me welcome you to TFP!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Welcome to the forum!
    I agree if its that nasty. That region is spotty with Iron in the water as you may well know, so just make sure you get the good stuff.
    Essential Links:
