Thread: Cyanuric Acid Reducer?
    Jun 2008
    Marana, AZ
    347
    Over at Leslie's pool yesterday, I saw a bottle labeled cyanuric acid reducer. Anyone have any experience with this? Does it reduce cyanuric acid or is it a money grabber?
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Cyanuric Acid Reducer?
    The good news is that you LEFT it there! Too expensive for too little results----if any.
    Bio Active Cyanuric Acid reducer review
    FYI
    triptyx's Avatar
    Apr 2016
    1,476
    Hi there fellow Arizonan!
    The only reasonably affordable way to reduce CYA is to drain water out of the pool and refill it. This same problem is what brought me to TFP last year - I ended up draining and refilling - it was worth it!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2015
    TN
    326
    Drain your water. The only way to get CYA out of your pool.
    It can be done! I had a CYA level of around 300 when we moved in our house. The previous owner used at least 12 chlorine tablets in floaters at all times.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Jun 2008
    Marana, AZ
    347
    Thanks. I don't have too much CYA in my water (I'm running around 50), but a co-worker does. I myself was wondering about it because I was going on a 2 week vacation and was wondering if I could use tablets and have a 'quick and easy' way to get the CYA down if it got too high. Looks like this is a money grab.
    Hayward sand filter
