Thread: Pool Opening Issues
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Pool Opening Issues
    I've got a few things going on during opening. First, I have a green pool. It's the very first time I've opened green. I'm not too worried, I'm following the plans outlined on this site. However, I do have a few other things. My drain plug on my pump housing is stripped out. Plan A is to fill the hole with silicone sealant and insert the plug. Plan B will involve a black rubber plug. Is there anything else that you have found that works on this?
    My pool level is low on start. I know we had 5" less rain this last period my pool was closed vs previous year. Also, we had a long warm fall that could have led to more evaporation than usual. Should I be concerned about this? Most seasons water starts to protrude through the cover. This season, I was about an inch above my return line and never made it to the bottom of the skimmer. Let me know your thoughts.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Opening Issues
    I think you have a good plan on fixing the drain plug. Is there only one or two drain plugs like on some pumps?
    I wouldn't be too concerned about the water level. I would certainly mark that current level so that you know where it was. If you refill, then start to noticeably lose water, somewhere at that height you marked before filling is where to look for problems.
    Isolated Spa - 345 Gallons
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Thanks for the advice. I have it marked. It's amazing how much my pool cleaned up today. Also my silicone plug is holding.
