Results 1 to 12 of 12
Thread: PH not going down
    Feb 2017
    Tampa
    25
    PH not going down
    Trying to lower our PH before slamming our pool.
    FC = 0
    PH = 8.4
    TA = 80
    CH = 380
    CYA 60
    Salt = 3750
    Kept adding plenty of bleach and the FC would drop to zero later in the day, so I am trying to lower our PH before Slamming with bleach. Problem is we added a gallon of muriatic acid 31% over a day and the pool is still over 8.0. The water is clear as day.
    Not sure if we should keep adding MA or look at something else first?
    40x24 round/kidney shaped, IG 28k gal, Built in 82, 2017 Resurfaced pebble tec. Hayward DE Filter DE2420 1.5hp, Hayward SP0710XR50 Vari-Flo Pool Valve, marathon motor 1.00 HP, 1.50 SF, 1.50 THP, Circupool SJ Series 40,000 and Dolphin nautilus pool cleaner.
    Jan 2012
    'burbs of Augusta, Georgia
    8,592
    Re: PH not going down
    What are the chances of it being much higher than 8.4 originally? Do you run a lot of water features that would cause a higher pH?
    I'd make sure you had full strength MA and do another dose.... 78 ounces should get you down to 7.2 from 8.0
    Test again after it mixes in and let us know wehre you are, ok??
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Welcome to TFP,
    What kit are you using? Your pH may be very high, but please let us know the answer on the kit before proceeding.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I'm not familiar with any pH tests that measure 8.4. Most stop at 8.0 or 8.2 and if pH is higher than that it still looks like 8.0 or 8.2. So, pH is likely much higher than 8.0. Also, pH is a logarithmic scale and the farther put you get from 7 the bigger the delta is, i.e. 7.6 to 7.7 is a much smaller jump than 8.3 to 8.4. Add enough acid to lower PH from 8.2 to 7.6, according to PoolMath, let it mix for 15 minutes or so and retest. Continue until pH shows up on the test.
    Jan 2012
    8,592
    <"nevermind" yippee says in her best churchlady voice>
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I just looked and He has a new K2006. I don't know if they go to 8.4 or not.
    Either way...Go ahead and add another gallon if your are certain of the 8.0 reading and report back.
    LOL- We are all posting at the same moments.
    Essential Links:
    Feb 2017
    Tampa
    25
    It could be higher. We don't run any extra water features but have been running the new SWG. Using the Taylor k2006 kit. I also had a pool store check it since I was using a lot of drops on the PH test. I will try more MA this afternoon and see if it comes down
    DFW, TX
    24,974
    I have the new 9056 comparator block that reads FC up to 10 and the pH test only goes to 8.0.
    This one
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    It will come down with enough acid, I promise. Just add a little at a time like this, and check. It will fall.
    Essential Links:
    Feb 2017
    Tampa
    25
    Added another gallon and dropped to a PH of 7.4. Thanks
    triptyx's Avatar
    Apr 2016
    1,476
    No worries! Stay on top of that pH - you don't want it to go above 8.0. With an SWG, you'll get even more of a rise over time than non-salt pools.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Excellent Tom, good to hear!
    Essential Links:
