Thread: When should I start - Arizona
    Jul 2013
    Phoenix, AZ
    67
    I only have my pump running for one hour all winter. Now the temps are 90 during the day and 55 at night.
    When should I start my normal chlorine treatments and running the pump for longer periods. We are not swimming yet. Probably won't until end of May.
    Thanks
    10,000 gallon IG pebble pool, 1,200 gallon raised spa, built 2006, Hayward Mega Plus 700 cartridge filter, Hayward Northstar SP4015NS 1.5hp pump, Hayward Super II 2.5hp spa pump w/blower, Jandy AquaLink RS, SpaLink RS controller, A&A Quik Leveler, Quik Clean In-floor cleaning/leaf vac, Laars LX 400 heater, Fiberstars 6004 fiber optic light. Massive delamination of ShastaDeck cool decking.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: When should I start - Arizona
    What's the water temperature? You want to make sure you're maintaining FC levels and balance out your pH before the water rises above 60 degrees... which it likely is already (always?). Pump run time likely needs to be at least a couple hours per day, more as the temperature rises to suit your chlorination and clarity needs.
    What does the water look like now?
    Isolated Spa - 345 Gallons
    Jul 2013
    Phoenix, AZ
    67
    Thank you. Water is about 70. Water is clear no issues.
    tucsontico's Avatar
    Mar 2014
    227
    Have you tested your water recently? If not, do so today and post your results. Even though it looks clear, I'll bet you need to get chlorine in the pool!
    BTW, I'm in Tucson and my water temp has been above 60º since late Feb. Right now it is 86º–that's without any supplemental heater! All I use is a solar cover to slow down evaporation but it does hold in the heat overnight which raises the temp quite nicely. Been swimming since the end of Mar (when water reached 80º)!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
