Thread: Help with stains
    May 2016
    ada, mo
    32
    Help with stains
    I have these stains that will not go away on my steps. They keep getting worse. They will not brush away. Any suggestions on what it could be or to do?
    FC-5
    CYA-60
    PH 7.4
    CH-200
    TA-70
    17,000 gallons free form. Pentair Intelliflo VS pump, Pentair Heater, SWG, Easy Touch.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Help with stains
    Have you ever had your pool or fill water tested for metals? What is the source? Well or municipal? Any algae outbreaks recently?
    Isolated Spa - 345 Gallons
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2016
    ada, mo
    32
    Sorry I have been out of town. It has never been tested for metals. It is municipal water. I just opened the pool. I tried the Vitamin C tabs to see if it lightened it up and it did nothing.
    Feb 2014
    Central Minnesota
    5,080
    Next step is to put a chlorine puck on the stains for a minute or so. They could be residual organic stains from a previous algae issue. If the trichlor puck fades them, it's likely organic and they could fade over time as you maintain proper sanitation.
