Thread: looking for correct o ring
    rajung's Avatar
    Mar 2015
    Iowa
    257
    Anyone using a PVC union made by American valve?
    Each year after removing and going to reinstall the next spring,I remove the o rings and apply some silicone grease to them
    Also, every so often a few seem too large and will not go back in slot.
    The union I purchased at Lowes but is now discontinued there as well as not showing up on mfg. website.
    American Valve, Lowes # 188223
    number molded on one slip end on sleeve is 240-121 DN40 1 1/2"
    I would just like to get a few o rings instead of swapping out the union for right now.
    Thanks
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: looking for correct o ring
    Lowes has drawers with o-rings on the hardware aisle.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Best thing to do is bring the fitting to an auto parts or hardware store where they should have a large variety of o-rings you can try for fit.
    Isolated Spa - 345 Gallons
    rajung's Avatar
    Mar 2015
    Iowa
    257
    Any idea if the BUNA rings are ok to use? I know I used them when I did engine/Diesel repair bu not sure on Pool.Most all I see are the EPDM used on pools, I know these are less expensive than BUNA
    Feb 2014
    Central Minnesota
    5,080
    I think either would be fine. Most of the time with o-rings you either need oil resistance or not. Would not need it in the case of pool water.
