Thread: Dirt coming back through returns...while vacuuming to waste
    texas247's Avatar
    Apr 2017
    Nederland, TX
    2
    Hi! Thank you so much for your work here and the advice you've given the old crowd at Ben's forum! Since that forum is now all but defunct, I would like to ask a question that I haven't seen answered yet. When opening my pool this year, I had quite a bit of debris. In order to remove as much as I could as quickly as I could, I tried vacuuming to waste. I noticed that I am seeing the fine debris (sand, dead algae, etc.) coming from the returns while vacuuming to waste, which should not be happening. After changing the multiport valve back to filter (AFTER backwashing and adding more DE), I found DE coming from the returns. I feel like there may possibly be a tear in one of my grids, but I don't know that this would explain the dirt from the returns while in "waste" mode. Any words of wisdom?
    26,000 gal, inground with vinyl liner, 1.0 HP pump, Pentair Nautilus DE filter, Hayward Vari-flo multiport, BBB method
    Jun 2014
    17,343
    Re: Dirt coming back through returns...while vacuuming to waste
    Hello and welcome to TFP! It's kind of sounding like your multiport valve is the issue - the spider gasket perhaps. When vacuuming to waste there should be no debris going to the filter, everything goes straight to the lawn. Is your filter/valve very old? Since you've had it, have you been careful to turn the valve in one constant direction and not go back & forth (left & right)? Changing directions has been known to bind or crimp the rubber spider gasket at times.
    texas247's Avatar
    Apr 2017
    Nederland, TX
    2
    Thanks, Pat! Today I replaced the spider gasket and O-ring to the multiport valve, and my husband and I also broke down the entire filter assembly to check for tears and breakdown in the grids. Thankfully, everything looked good and we got it put back together with no problems. I didn't see any DE go back into the pool from the returns when I was replacing that, so it seems the filter is in good shape. I did notice, however, that there is still water coming from the returns while the multiport is set to "waste." I can't find any leaks anywhere else so I am at a complete loss as to what could be causing this problem!
    Jun 2014
    17,343
    Humm. That is odd. I would've bet odds in Vegas the spider gasket would do the trick.
