Results 1 to 9 of 9
Thread: Ultra Pure and Nature 2 Fusion In-Ground
    lardo5150's Avatar
    Apr 2017
    Little Elm Texas
    114
    First post everyone. We are starting the process of getting our pool.
    Going with same builder that my neighbor went with. Liked everything they did.
    We are in Dallas Texas by the way.
    Doing some research on here. My neighbor got the Ultra Pure (the ultraviolet light thing), and the Nature 2 Fusion In-Ground (I believe this is the correct one as it is for a chlorine pool).
    Did some research, seems everyone thinks the Ultra Pure is a waste of money for where I live?
    How about the Nature 2 Fusion In-Ground. Supposed to be a mineral sanitizer? Pic Attached.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,314
    Re: Ultra Pure and Nature 2 Fusion In-Ground
    Lardo, (You don't get to say that and not get in trouble, too often...)
    Welcome to TFP... A Great resource for all your new pool questions...
    Sorry, but you will not find much support for using 3" tablets, UV systems nor mineral systems here at TFP..
    Here are the three ways that we recommend a pool be maintained...
    1. Manually add Liquid Chlorine or plain Bleach on a regular basis. Usually daily or ever other day.
    2. Use a Stenner pump to automatically add Liquid Chlorine or bleach.
    3. Use a Saltwater Chlorine Generator (SWCG) to convert the salt in your pool into chlorine.
    I'll let some of our chemical experts chime in as to why we don't approve of other methods...
    Thanks for posting,
    JoyfulNoise's Avatar
    May 2015
    14,094
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    After you read... I will say this. When my pool was built, they included that Nature2 unit. I didn't know much about it, other than the starter cartridge would last the remainder of the season, and my pool builder would be happy to sell me a replacement at opening. My understanding is that the Nature2 unit is provided free to pool builders.
    Knowing better now, I will keep it inline as it will serve nicely as a puck feeder when we're away on vacation or something. Otherwise it does nothing more than connect two pipes... I assume there was a plug for the mineral cartridge that was thrown away when the "starter" cartridge was installed. I was able to take it apart and get the mineral pellets out, and now use the empty cartridge as a plug.
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    Dec 2016
    Arlington, Texas
    291
    Howdy Lardo, I bought my first pool in September 2016 and it came with a house. I struggled with pool service companies, tabs, and algae for 3 months before asking The Great Google for a better way. I found TFP in December and quickly fired the pool service company, saving $160 per month, and started buying bleach. Feb this year I switched to a SWG and that dude is awesome! I have heard many people say, once you go SWG, you won't go back. I am now one of those people. The only time I hear anything negative about SWG is from ignorant people, and they can be enlightened, if they are open to it. You have the opportunity to set this up exactly how you want from the beginning. Do the reading above, ask more questions (preferably to the non-ignorants), do your own research, and make the decision that is best for you.
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Jan 2017
    Monterrey, NL, Mexico
    492
    Here at TFP its all about the KISS principle(Keep It Simple)
    im also a SWG fan and use the stenner type pump for Muratic Acid.
    Cant get any more simple than that.
    Good luck!
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    lardo5150's Avatar
    Apr 2017
    Little Elm Texas
    114
    well, we are going salt. So not getting any of this stuff.
    Looks like I am going with Pentair
    Dec 2016
    Arlington, Texas
    291
    Those are both great choices! Make sure you get a good test kit. The TF-100 is the best kit out there. Add the speedstir option as well.
    Jun 2015
    Mandeville, LA
    109
    My pool builder installed the Fusionsoft which is SWG and Nature 2 in one unit. I just never installed the N2 cartridge and left in the shipping plug.
