Thread: SD80 Filter Cracked
    Oct 2015
    Dudley, Ga
    22
    SD80 Filter Cracked
    Our pool is roughly 4 years old, I believe this will be the fifth season (second owners). Being in middle Georgia,meet don't close our pool for the winter, we just add liquid chlorine as needed when the water gets too cold for the SWG. Noticed during the winter that our Sand Dollar SD80 filter has developed small holes along one of the two seams. Pressure hasn't been an issue, I backwash and rinse at least once a week, more if the pressure rises. Deep cleaned the filter last spring.
    Here's my question: has anyone else had this happen? Possible causes? Is there any way to fix or do we just need to but the bullet and get a new filter?
    28,000 gal IG vinyl, sand filter, 1.5 hp pump, sand filter, SWG (Intellichlor), booster pump for Polaris, Well water fill, Pentair control panel
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SD80 Filter Cracked
    Pictures of the holes would help if they are visible. I would find it odd that after only 4 seasons there would be a structural problem with the filter housing (I'm assuming the holes are on the outer housing).
    Isolated Spa - 345 Gallons
    Oct 2015
    Dudley, Ga
    22
    I'll see if I can get some. They're not very big but are big enough to create a spray when the pump is running. It may be easier to get a pic of the spray than the actual holes. They are in the seam of the outer shell of the filter.
    Feb 2014
    Central Minnesota
    5,080
    If water is spraying from the filter housing, you need to replace. I'd be a bit upset if my filter housing failed after that little time. It's a very basic part of the filter and needs to withstand pressure. Looks like Pentair filters only have a one year warranty, but I'd call and tell them about your issue and/or send them images of the failure with complaints.
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    489
    Quote Originally Posted by Izzyc123 View Post
    The fact the failure appears to be on the seam indicates a manufacturing defect. I agree with JV you should contact contact the manufacturer. Since your leak is on the seam they may well replace the case for you at least. 4 years is way shorter than any filter I've heard of.
    I hope this helps.
    Chris
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
