Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: My 18x52 Intex Ultra Build - Mods: skimmer, inlets,outlets, return-PVC Diagrams/Video
    Jun 2016
    Pittsburgh, pa
    369
    I had a few posts on the various topics in my title, found out the info i needed (i hope), so i decided I'd put this all together in one thread. Some of the things in here some may find useful, because the info is very hard to figure out or find.. I'll try to break this down as best I can over the next month or so.
    First up is the Pool itself.
    Its an Intex Ultra Frame 18 foot by 52" deep 6981 Gallon pool. I got it for around $599 at the end of june 2016.
    The items i have in play are in my sig but here they are:
    Sand Pump System(0.5 hp and 12"?): Intex SF80110 2100 GPH + pump (came with system) $120 new
    Salt water system: Krystal Clear 7000 Gallon Salt Water System $107 bought later
    **I think it says in the manual 3-4 hours per day to run, however, last years setting is showing 7 hours per day, i need to double check this, also depends on CYA being normal too.
    Intex Solar cover: $34 (i cant recall if this ended up being the intex brand or a 3rd party, but very similar either way)
    **I may later try the solar panel kit (smartpool s601p) $246 you can put on say a roof and plumb the water through it, for ultimate early season heating.
    Salt tester i use to test just salt levels: Eseasongear Salt-3000 $24 (keep around 3000 ppm)
    Ph Tester $15.67 (for quick tests)
    TF-100 Test kit $70
    CYA (to keep around 70-80) $15 (i usually hang in a sock on the side throughout the season)
    Salt for the salt water system/pool: Diamond Crystal 40lb $7.56 ( i forget for a "clean" pool water setup how many bags i used, i think 4.5 or 170lbs on first use)
    Sand for the sand pump: 1 bags of 50lb sand
    HTH sand 61308 $13 at ace or this HTH 67074 $12 would work too, i used the 61308
    **from the manual: Use No. 20 silica sand or glass sand with particle size range 0.45 to 0.85 mm (0.018 to 0.033 inches) and a Uniformity Coefficient less than 1.75.
    Gorilla pad under the pool: $75
    **deluxe wall mount skimmer (now being replaced with inwall variety) $20
    **I may later upgrade to the 4500 gph 19" 1HP SKY1639 BestChoice Sand Pump system $239 found on here often (to give more power for things like a floor robot, but likely wont need it based on comments).
    UPDATE: this is in progress
    After a month or so i started to see rust on the joints of the pool. I decided to put rustoleum gray paint on those areas as well as "rescue tape" wrapped around the same areas.. no issues since.
    When i put the pool in, i had someone come with a bull dozer, then i put a layer of sand down (i forget how many ton).. unfortunately somewhere along the line i didnt have it perfectly level, despite using levels and boards to try to get it close. One side might have 2.5 blocks showing from the top while others are at 1 block from the top.. i try to keep it at its "highest point" about 1.5 blocks from the top.
    I then added a wooden deck to the pool which has worked out great, though i wish i had extended it about 3 feet further towards the garage so that there is more "splash-free" zone available. I believe the total cost for this deck, not counting the rocks i added around the pool, was in the neighborhood of $900 from lowes. I believe i used 16 foot going from the start of this picture to the rear and from left to right used 12 foot boards cut to length for each part around the semi circle.
    I also purchased steps for the pool and a matt for under it.
    They are the Confer CCAG 4 step for around $180 on amazon.
    I added an intex light to the side too..
    On the backside i have an equipment gate, under the deck is the salt water filter system and return inlet.
    This was all done between july and early august last year.
    In the fall i bought an 18' pool cover to cover the pool.. tried using jugs filled with water hanging off the pool on nylon string, as well as nylon string pulling the side by the deck to the deck, since it was next to impossible to get the tarp down under the deck edge.. this worked ok for a month or two, along with an R16 auto tube (which seemed kinda small but i guess was good enough to break ice), then the tarp blew off from the left side and for the last 2 months was exposed. I think next year ill get a 21' tarp (pool mate 5718-4 $66) and find some sort of pegs to jam into the ground to tie it down with.. still have an issue on the side by the deck though. When i took the tarp off around april 10th, there was a ton of water up on top of the tarp.. i ended up using a shop vac to try to remove most of that green water, very tedious, i know there are better ways.
    So april is here, tarp off, ready to roll. I hastily increased the water back to normal levels, from the fall where i was below the Two outlet ports. Only to decide i want to put in bigger outlets, a hayward widemouth skimmer, pvc piping, some splits on the return piping for a future robot and possibly add a second eyeball hayward return about 16" below the existing regular return for efficiency.
    Ill update this thread as this part moves forward along with parts used and pictures (as well as last years pics)....
    Up first are this years mods i will attemp..
    Hayward Sidwall Skimmer Mod + PVC
    I've decided to go with the Hayward WideMouth, so i can keep the water level near normal (though you could with the standard too, just raise it up higher).
    Model: SP1091WM $41
    This filter comes with the round disc you put ontop of the basket inside to do regular vacuuming of the pool, using a standard bagless head (which i've just ordered as well).
    The filter comes with a gasket that is "butterfly" in nature, meaning the edges of it are cut/flapped, so you can put the gasket "around" the liner after its cut. Many have said they cut the gasket into 2 pieces, one outside, one inside pool and had success (or added silicone to the outside)..
    I've decided i will NOT cut it.. I'm going to go ahead and mount the hayward bracket with the gasket as is, on the Inside of the pool (initially).. take a drill make the holes, feed the bolts through and secure the backside (ill lower the water down as well, after i get the exact height that is halfway or 3/4 on the skimmer bracket)..
    Once all this is in place, ill make the cut for the hole.. then ill take it apart again and put the gasket where it belongs overlapping the seem of the liner.
    Below is a picture showing the dual outlets i currently have.. the red circle to the right (but higher up in the gray area) is where i intend to put the sidewall skimmer.
    To go along with this, i will re-use the 24' 1.25" hose that came with the deluxe kit with the intex..
    I bought a new vacuum head:
    Poolmaster 18525 Jumbo Head $24
    Replacing the two outlets with bigger strainers/connections
    The other task which will come in a few days, is removing the old strainers and putting in the new ones, using these:
    Intex 11236 large strainers $22 for two shipped
    **these come with the nut that goes flush against the pool and the washers for each side.
    The issue is, that right now at least, both of these are under water.. its my understanding i should be able to hold a bowl inside the pool and make the cut on the outside and somehow fish them through and quickly put each gasket in place and screw together.
    Not sure how i can have it on the outside then after the cut push the larger side of it through, but we will see (or ill just drain it down a tad, again)
    This leads me to converting to mostly PVC connections
    I intend to still use the flex hoses off the equipment, which i believe are standard 1.5" connections..
    The reason for switching to the large strainers from intex is that the threads should also be 1.5"
    Ultimately though, i want to split the return side like "Jeffchap" did with his pic here, but with an added hayward return in the middle here (two returns into the pool)
    While on the otherside i will go for something like this which "domct203" did per his image:
    See below for the full list of PVC and related parts used as well as my actual end result...
    UPDATE:
    Hayward mod:
    I decided to just cut the gasket into two, making two gaskets.. one for the outside and one for the inside, but i stupidly forgot to put the outside gasket on (no leaks after super tightening).. ill either silicone the outside or take it apart and fix, assuming no risk to the already cut hole stretching. It was easy to make the hole cut as well, using push out box cutter, after everything was secured. Water levels will go to the second screw up at the two thirds mark when full.. it was as high as i could get it without interfering with the "bend" of the gray material on the back of the pool and keeping it flush.. i'm glad i went widemouth..
    Update: i pulled it off/unscrewed it, added the gasket to the rear, re attached.. no issues.
    Before adding water again:
    Here are some updated pics of the haywood now that the pvc is done and the water levels are up to normal (to the second screw on the haywood)..
    Here is a closer view on the connections as well:
    Here is the full list of parts used/with diagram:
    1: Haywood connector
    2: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    3: Lasco 1.5" adapter with male inner threads 435015RMC
    4: PVC right angle slip on both ends 90 degree 409015RMC
    5: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    6: Ball valve 1.5" 1.5" non threaded ball valves
    7: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    8: Right angle 90 degree male inner thread and slip on other end 407015RMC
    9: PVC Tee with slip ends 401015RMC
    10: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    11: GAME 40mm to 1.5" adapter with washer Game 4560 adapters
    12: 1.5" pvc cut pipe
    13: Union Connector 511-14-112-112B
    14: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    15: 45 degree 1.5" slip ends 436015RMC
    16: PVC 1.5" cut pipe
    17: Right angle 90 degree slip on both ends 409015RMC
    18: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    19: Ball valve 1.5" 1.5" non threaded ball valves
    20: PVC 1.5" cut pipe joiner (not the same as a pvc coupler found at stores)
    21: Lasco 1.5" adapter with male inner threads 435015RMC
    The rest of the PVC items needed to make all this happen:
    Then the parts of the return PVC in addition, which are the same basic concept.
    Generic PVC piping 1.5", roughly 8-10 feet or more
    Hayward overlfow mod
    I'm also going to drill a hole in the hayward about 1" above the water level and from there a 90 degree bend and 1/2 pvc pipe to the ground, this will serve as an overflow regulator..
    Need 1/2" 90 degree bend :98cents
    another 1/2 non threaded for on the ground: 48cents
    1/2 PVC pipe, 5 foot section, two of them
    Lastly, teflon tape $4(blue hawk 0.6x21), better grade variety.
    Total in PVC around $87 plus a few sections of straight 1.5" pipe; Along with the cement/primer kit $9.38 to mix together
    Hayward Connector parts:
    Strainer Cap
    Plug (has a washer which is key)
    Here is animated gif showing the construction of the pool and deck from 2016:
    Here is a short overview video on whats been done through 4/21/17:
    Intex UltraFrame 18x52 pool with pvc mods and intex robot - YouTube
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: My 18x52 Intex Ultra Frame Build - Mods: skimmer change, inlets and outlets and P
    Cool stuff!
    Kepp us updated and good luck with everything.
    Essential Links:
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by Patrick_B View Post
    Cool stuff!
    Thank you
    Some pictures and more details added to the main post.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Nice deck! I haven't gotten around to that yet.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by jeffchap View Post
    Thank you sir.. it makes the whole thing feel more real once its in place
    Jun 2016
    Pittsburgh, pa
    369
    I've added the pics of the hayward mod that i have done so far.. next up will be swapping out the outlet ports and putting in the hayward (3/4"?) return that came with the hayward filter (assuming its worth going with the hayward over the intex, maybe just because its 1.5" on the other end, i think).
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    The Hayward eyeball is well worth installing. The Intex one has a very diffuse flow and doesn't circulate the water nearly as well.
    Pentair IC40 SWG
    Jun 2016
    Pittsburgh, pa
    369
    The eyeball that came with the wide mouth appears to only be 0.75" in diameter (the open nozzle that sprays).. perhaps i should look for the larger nozzle hayward instead.. i think it would still be the same, though maybe the pipe is bigger behind it? edit: eh maybe they dont have any bigger nozzle sizes anyway, so the gain must be in the pipe size going into the pool
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    It sprays harder precisely because it is coming through a smaller opening. That's what makes it better.
    Pentair IC40 SWG
    Jun 2016
    Pittsburgh, pa
    369
    Ah yes of course.. makes sense.. so i took the old one off.. i think i found what may have been mentioned elsewhere.. that the existing return hole is about .25" bigger around than the new Hayward return size.. so the question is.. silicone around it once through on the outside.. or just cap the old one and make a new return hole maybe 6" to the right (and slightly lower) than the old one?
    Or i may just go directly below the old one about 12-14" (and only use this "deeper" haywood).. this should be ok right, being deeper (and the only one)? edit: looks like on avg most just put the hayward on with no leaks.. so i'm gonna go that route, in the old hole.
    Jun 2016
    Pittsburgh, pa
    369
    Re: My 18x52 Intex Ultra Frame Build - Mods: skimmer, inlets,outlets, new return-PVC
    It also looks like my sand pump hoses will screw directly onto PVC without the need for the game adapters.. (with a flush connection basically, and the threaded nut holding it together.. there arent threads inside the hose, only in the threaded nut on the end, which match 1.5" threads)
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Because the threads are slightly different, you'll have to add a second rubber washer to keep it from leaking. Without it, the Intex collars won't screw down tight enough to stop it from leaking.
    I picked some up from my local Ace Hardware.
    Pentair IC40 SWG
    Jun 2016
    Pittsburgh, pa
    369
    Added some pics to the first post.. pvc part done or mostly done. Yeah that new eyeball really pushes it out In looking at my pvc going from the haywood to the second outlet to the pump, i think it should be level or go downhill.. i didnt do this.. i may have to modify the left outlet to be slightly longer to make it level or dip at that point.
    I also found that if i use the ball to turn off the flow to the second outlet without a plug in it, the pump gets air and the water drops inside it.. not sure why.
    My left outlet ring is leaking at the nut/thread.. ill either try to add silicone (may not work since its dripping) or remove it quickly and add teflon.
    I added the washers to the game adapters, no leaks there are anywhere else thus far.. all pvd'd up on the return area.. just need one pvc connector with the inside threads and a game connector and i can easily add the robot later perhaps
    domct203's Avatar
    Jun 2015
    CT
    3,896
    Project is looking great!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by domct203 View Post
    Thanks.. appreciate all the tips you and others have provided along the way. Next up, maybe adjusting the angle on the pipe and deciding if i'm going for that different pump or not (the 4500 gph cheaper one vs a hayward), then a robot, likely my next option. Likely will pull the trigger on the 4500gph 19" best choice pump in the next few days, then dual suction should work well.
    Jun 2016
    Pittsburgh, pa
    369
    I've added a diagram showing exactly which pvc/hayward parts were used, hopefully this helps others trying to piece together the puzzle
    Jun 2016
    Pittsburgh, pa
    369
    I'm definitely going for the 4500 gph pump.. having both suction and hayward on results in little suction from each, shutting off the extra suction makes the hayward really "suck".. i'm pretty sure that once the 4500 is in place, both should have pretty equal pressure or alot more when both used
    Jun 2014
    17,327
    Re: My 18x52 Intex Ultra Build - Mods: skimmer, inlets,outlets, new return-PVC Diagra
    Gee, what a fabulous thread. Great work all around.
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by Texas Splash View Post
    Thanks Still in progress, of course i guess arent all our pools over time.. an addiction now to make things even better
  20. Back To Top    #20
    Jun 2016
    Pittsburgh, pa
    369
    Added a gif animation showing the construction from start to finish of pool/deck.. at the bottom of the first post. A tripod would have been better, but it would have been hard to leave up for 25 days or so
