Results 1 to 13 of 13
Thread: Which Salt brand to use
    Jul 2015
    Miami, Fl
    32
    Hello all. I had my pool replastered about 4 weeks ago so it's time to add the salt and startup the salt water chlorination. I'm looking for suggestions to salt brands to use as I'm not to fond of what my local pool store sells? Any feedback appreciated. Thanks
    May 2011
    lebanon tn
    370
    Re: Which Salt brand to use
    Cheapest pure salt you can find. Usually water softener salt in 40lb bags without additives like iron out. Should say 99% pure. Walmart, lowes, Home Depot, etc all carry it
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    JoyfulNoise's Avatar
    May 2015
    14,094
    Most folks here buy solar salt from the hardware store; the kind you use in a water softener. You can "pool salt" from the pool store but it's not any better and its typically more expensive.
    Matt
    Jul 2015
    Miami, Fl
    32
    I found this one at my local Lowes. Recommended? Morton 40-lb Salt Solar Crystals
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Sure, that is fine.
    Jul 2015
    Miami, Fl
    32
    Good day all. Is it recommended to dilute the salt into a bucket first and then pour into pull or just spread each bag of salt around pool? I'm calculating around 8 bags for 12k gallons pool. Thanks
    May 2015
    14,094
    Nope. Just dump it in and brush it around. Try not to let it sit in one spot for extended periods of time. Having kids in the pool to splash and play helps with mixing.
    It can take anywhere from 24-48hours for salt to properly mix and homogenize, so don't turn on any SWGs for a few days or else you'll get lots of LOW and HIGH salt errors.
    Matt
    Jul 2015
    Miami, Fl
    32
    Hello all. I went to lowes and Walmart and I found the solar salt, but it's crystal type not granulated salt. Can I use these and will they dissolve as fast as the granulated pool salt? Let me know. Thanks.
    40,892
    All I ever use in my pool is solar salt from Lowe's.
    It may not dissolve as fast but that really doesn't matter. It might take 30 minutes instead of 10 minutes. But actually my kids like to play with the salt while it's dissolving.
    Jul 2015
    Miami, Fl
    32
    When you say Lowes, does lowes have their own brand or are you referring to the Morton Solar salt they sell as that is what I'm finding locally.
    40,892
    Morton
    Aug 2013
    Oklahoma City, OK
    158
    Wow..who knew salt could be so complex!
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Jul 2015
    Miami, Fl
    32
    Not complex just trying to do it right. I did before the pool store salt and it made us all itch even with all perfectly balanced. Trying to avoid it this time. Thanks again for all info.
