Thread: Metal sequestrant chlorine tolerance
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,802
    Day before yesterday I came home to a freshly green pool. I opened it about a week ago with iron staining like I had last year. I added some hth brand metal sequestrant to give it a try since it was considerably cheaper than the Jack's I used last year. It removed the stains, and the pool looked great. I'd been adding a gallon of liquid chlorine a day while I was letting the filter and pool cleaner do their thing. Turns out I let my chlorine level get a little high since I was just adding a little liquid chlorine each day without testing, and it messed with the hth metal sequestrant I had put in it. Here's where it gets weird, at least to me; FC was 11.5 the day before yesterday with roughly 75 cya. I made sure the swg was off. Yesterday it was pretty and blue again with just a tiny bit of residual discoloration, so I figured the chlorine had dropped and the sequestrant was doing its job again. Well, the FC was still 11. Does this have more to do with the FC level, or the possible ph fluctuation based on that FC level? My ph was 7.5 when I opened the pool.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Metal sequestrant chlorine tolerance
    Yes, it is more about the pH with iron and green water. FC sometimes will cause a pH bump that will make it seem like it is the FC level. I've seen quite a few times that 7.5 to 7.6 is about the cutoff point. The higher FC level can chew up your sequestrant a bit faster.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,802
    Ok. So the higher ph caused it to break the bond with the iron, then as the FC came down, the ph also came down, and allowed it to re-bind with the iron? Hopefully this warm day today will burn off enough FC that I can get an accurate ph reading to verify.
    DFW, TX
    24,974
    Yes, that is the ticket.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,802
    Ok. I was worried that the higher FC had just obliterated the sequestrant, and I'd have to add it all over again. I was relieved when it turned back to blue. Glad it's still there, and doing its job.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,802
    Pool looks even better today. FC is 9, and ph is 7.2. I'm guessing the cya I added during all this dropped the ph. Surely a couple points of FC couldn't have raised it that much. The whole thing still seems weird, but at least it's back to looking blue.
