Results 1 to 11 of 11
Thread: Considering opening pool ourselves
    Deb04's Avatar
    Jul 2008
    Seacoast, NH
    333
    This will be our 10th summer with our pool and we have had a TFP since day 1.
    We have never opened or closed the pool ourselves, we've always had the PB do it, just because we didn't want to do the work. We're considering opening it ourselves this year.
    I've read the sticky on pool opening. I feel pretty comfortable with everything except installing the ladder and the railing. There aren't any instructions on how to do that. Are there bolts or does gravity hold them in?
    Also, somewhere along the line we lost the wrench to turn the screws holding the cover in place. Where would you recommend getting another? Amazon?
    Below is a pic of the pool right after construction, before landscaping, so you can see the design of ladder and railing.
    TIA
    19,000 gallons, Well Water, Built in 2008
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Considering opening pool ourselves
    If you can take a picture of the screw head it would help us prevent you buying the wrong type. I'm picturing Allen screws, but wildly guessing since I cant see it.
    If there are no other set, or anchor screws, I am guessing it just slides in. Hopefully someone with that type can be of more help. Congrats on all your successes with TFP!
    Essential Links:
    May 2013
    Ontario, Canada
    63
    I have a similar ladder and mine uses a socket. When you put the ladder into the holes, pull the circular covers up so you can see the bolts and then tighten them up (finger tight). There is nothing to it.
    A picture of your fastener or the exposed hole with the brass bolts would be helpful. Good luck and enjoy the savings!
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    May 2016
    Troy IL
    484
    We used to have a similar looking ladder on a pool in our house as a kid. It just slid in and out. Those metal sleeves cover the hole. I'd lift them up, and as said, if you see no screws or bolts, then just pull or push it in.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Deb04's Avatar
    Jul 2008
    Seacoast, NH
    333
    Thanks.
    This is the pool cover screw.
    Here's the ladder bolt.
    1.5 HP Pump
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,111
    The cover is just takes an Allen wrench. Re the ladder: loosen the bolt, slip the ladder into place then tighten the bolt. It pulls a wedge that holds the ladder in place. Do not over tighten the bolts, gravity alone will help keep it in place. Just snug is fine.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
    Apr 2017
    Maine
    231
    Easier than an Allen key is a cordless drill, put the bit in backwards and the head fits those anchor screws perfectly.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,981
    Quote Originally Posted by Chemnut View Post
    BUT you do NOT want to over tighten it! Best to do it by hand.
    Kim
    Apr 2017
    Maine
    231
    I believe that goes without saying for any screw or nut.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    100% open yourself- it's easy and not a lot of damage you can do.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Gor for it!
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
