Results 1 to 9 of 9
Thread: Trouble with sand returning to pool
    Apr 2017
    Bennington
    5
    I have an 18' x 48" pool with Hayward S180T Sand filter. I seem to always have trouble with sand returning to pool. I just hooked everything up this year including new valve, put in new sand and am getting sand in the return jet. I have replaced the laterals several times, most recent was 2 years ago.
    Am I doing something wrong? Is there an alternative to the type of finger lateral for the sand filter?
    Any help or suggestions would be greatly appreciated.
    Thank you,
    Steve
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,890
    Re: Trouble with sand returning to pool
    Steve, HI! I hope we can help you figure this out. The first question I need to ask is what kind of sand are you using? We will go on from there.
    Kim
    Jun 2014
    17,323
    Hello Steve and welcome to TFP! By any chance you can you confirm the sand used was "#20 silica pool sand"? There are some other sands out there, and some are slightly smaller in diameter which allows them to flow into/through the laterals thereby entering the pool. A couple other things could be too high pump pressure (force) (kind of doubt that's your problem though) and too much sand installed. Lastly, since your valve is new, maybe one of those new laterals simply didn't seat well during reassembly? Did you fill the tank up with some water before pouring the sand onto the laterals? We recommend that to prevent weight of the sand from moving/cracking a lateral.
    Nice to have you with us at TFP.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Also, be sure to rinse if your valve has a rinse position. More here, Pool School - Maintenance and Cleaning of Pool Filters
    Apr 2017
    Bennington
    5
    I will check sand when i get home. Told guy at pool store which filter i have, this is what he gave me. No i did not put water in before pouring sand in. Did not have to remove lateral to put new valve in. Old valve did same thing after backwash
    Apr 2017
    Bennington
    5
    It does have rinse
    Apr 2017
    Bennington
    5
    20170413_200106.jpg20170413_200228.jpg It doesn't say on the bag anywhere the size of the sand.
    It does have 49/20 on the side if that is to do with the size. 20170413_200147.jpg
    Jun 2014
    17,323
    That should be fine. I believe it means .49mm/#20.
    Apr 2017
    Bennington
    5
    I put in 3 bags into my filter. I will run rinse tomorrow to see if that helps at all.
    Thank you,
    Steve
