Results 1 to 19 of 19
Thread: Remove Diesel in pool
    Sep 2014
    Wharton County, Texas
    32
    Any ideas how to rid a pool system of about 2 quarts of diesel? At this point, I have put a few gallons of Clear Aid over the past few days that's supposed to help remove oils. We no longer see an oil film on top of the water.
    I've turned water on to the pool to let it overflow out my drain for a while.
    I've laid out oil absorbent pads in my spa before the overflow & the pool itself.
    Today I removed the 4 cartridge filters, sprayed out, soaked in muriatic acid & clear aid, then sprayed again. You can still see the oil film as you spray. Should I just throw these cartridges away or are they salvageable? I just purchased them last August. I do have a set of filters coming tomorrow.
    To how it got in there, not so funny story. Last summer my wife poured diesel into our riding mower. I drained the tank into a muriatic acid jug I had left over & sat it next to my gas & diesel jugs. Over spring break my wife just had to clean the garage. Well she put that muriatic acid jug with diesel in it on the pool chemical shelf. I'll let you guess the next part, but I was trying to lower my pH.
    Any help is greatly appreciated!!!!
    19K gallon free-formed w/ 60% Color Quartz plaster
    3.5' x 5.5' x 4' depths - 15' x 20' 15' widths - 12" oval raised spa with spillover
    Hayward 1.85 hp TriStar VS Pool & 1.25 hp water feature pump - Cartridge Filter
    Hayward OnCommand automation system - 400K BTU heater - LED lights for pool & spa
    20' weeping moss rock wall - 5' x 8' tanning ledge with bubbler
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: Remove Diesel in pool
    A solution if TSP (trisodium phosphate) will remove the diesel from the filters better than MA. You can get TSP at hardware stores in the paint section. Don't use the "phosphate free" TSP, you want REAL TSP if you can get it.
    As for the pool, not many options there but time and filtration. You're doing all the right things with Pig Mats and draining. The enzyme clarifiers aren't going to do much for your level of contamination. Chlorine and filtration are your friends.
    Are you seeing an overnight chlorine loss?
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Lowes has the real TSP up on the top shelf and the fake stuff down lower.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Quote Originally Posted by pooldv View Post
    Depending on state you live in, could be very hard to find. I think the real stuff id outlawed here in WA, but I did find it at a restaurant supply store.
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    Sep 2014
    32
    I do have a small container of TSP from when I refinished our cabinets. It was suggested to remove grease from them, which makes sense for this case as well.
    Should I soak them in the TSP or spray on as a mixed solution?
    In all honesty I haven't checked chemicals since this happened. Baseball games, etc consumed my time. Hopefully I'll have time tomorrow.
    The clarity has definitely improved. I left the cartridges out tonight and didn't plan to run pump until I get the cartridge situation figured out. I may put them back in the morning and let it run throughout the day then re-clean tomorrow.
    Thanks for the help!!
    May 2015
    14,083
    Soak them. Use the direction on the box. I think the standard cleaning formulation is 1/4cup per gallon of water. You can use a large plastic garbage can and try to soak all of them at once if you have multiple cartridges.
    Matt
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    I feel your pain. Two years ago I poured used motor oil in the pool. Fortunately I noticed right away and shut the pumps off.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,916
    Note to self............only store POOL chemicals in pool chemical bottles and containers! I can so see my husband doing the same thing your wife did. Not being bad but trying to help-bless their hearts LOL
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,607
    Quote Originally Posted by kimkats View Post
    +1
    This is simply a dangerous thing to do. Mix whatever is residual in a bottle of something else with pool chemicals
    and the reaction could be very bad.
    Dolphin E10 Cleaning Robot.
    Sep 2014
    32
    The sad part was, the red gas jug was labeled diesel with magic marker all over the place.
    May 2015
    14,083
    Quote Originally Posted by Keithb View Post
    Wel...THAT was the problem...proper diesel gas cans are YELLOW not RED....you should have had the diesel stored in it's proper container....
    Matt
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Sometimes you gotta do what you gotta do. I'm told that in the '70s during the oil embargo (slightly before my time...), my uncle had a small dump truck. He had his gasoline stolen twice. So, his solution was to write "DIESEL" in red paint on the gas tank. It wasn't a diesel truck, but he never got hit again...
    Sep 2014
    32
    Don't start with me! I've heard that. When I bought the jugs, there were no diesel jugs, just Kerosine.
    Sep 2014
    32
    Quote Originally Posted by borjis View Post
    +1
    FYI: there are neutralizing solutions to break down other chemicals to reuse containers. We use the same on the farm.
    Sep 2014
    32
    After rinsing, soaking in muriatic acid & clear aid, rinsing, soaking in TSP granule mixture & rinsing; I believe we got 99% of it gone. It was a very long process. We cleaned inside of filter, pump, and scrubbed the tile. Still have some pig mats in spa overflow to catch any residue. I believe those worked well.
    I think the clear aid allowed the filters to filter out the diesel and catch it there?
    Hopefully we'll be good to go! Thanks for all of your input!
    Jul 2012
    Tallahassee, FL
    33,916
    Thanks for the follow up! Good info for all to have if needed in the future!
    Kim
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    No such thing as diesel "gas"....it is diesel "fuel".
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Quote Originally Posted by Pyrodav View Post
    And gas stations never sell gas, only gasoline and sometimes diesel fuel...
    Aqua Lab Rat's Avatar
    May 2015
    Anoka, MN
    89
    Maybe use the Oilinator Pool Mousehttps://www.amazon.com/Oilinator-PSM.../dp/B00USBKK9C
    Made by a company that sells larger kits for oil spills.
    Lyle
    Professional product developer using & maintaining a dozen or so spas from 150 to 550 gallons, many pools from 1200 to 40,000 gallons (above-ground and in-ground), and a half-dozen test tanks.
    If it's not one thing, it's usually several others!
