Results 1 to 9 of 9
Thread: Test PH or Alkalinity First
    Red face Test PH or Alkalinity First
    When testing pool water should I test the ph or alkalinity first. One sight said to always check alk first. I know the Chlorine should be at the correct level first. I use TF -100 test kit. THANKS
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Mar 2016
    Gilbert AZ
    45
    Re: Test PH or Alkalinity First
    Doesn't matter the order...just check both to calculate the amount of Acid to use...I hardly ever check alk now...mine is extremely predictable.
    11,507 Gallons | In Ground Pebble Tec | QC XHP In Ground Cleaning System | System 3 MM Sta-Rite Filter | Pentair VS-T 3050 Pump | Pentair Ultra Temp 120 H/C | QuickPure 3 Ozone | K2006 Test Kit
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    If there were an order, I'd say PH first.
    Out of wack PH will do more harm than out of wack TA
    Dolphin E10 Cleaning Robot.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    To be honest, if you never checked TA it would probably not be the end of the world. It is always the last thing we say to worry about.
    Now, with that being said if you have what we call a quality test kit (Taylor K-2006C or a TF-100) at the beginning of the season run all of the tests to get a baseline. Then, worry about what is really important FC & pH.
    You are a hop skip & a jump from me, so here is what I do- - -
    I keep the pool open all year
    During the winter I check FC every couple of weeks.
    In the spring as it starts to warm I do a full battery of tests FC, CC, pH, TA, CYA & CH I adjust CYA & CH at that point for my plaster pool. You have vinyl, so unless it's outrageously high CH means nothing to you.
    I have a Stenner Pump auto-chlorinating my pool so every 2 or 3 days I check FC & pH. Once every 5 or six weeks I test TA, CYA & CH just to see what is going on.
    Generally, during the year my pool gets chlorine and acid to bring the pH down. That's it.
    Pool stores want to make is seem like your pool is going to fall apart if you don't constantly adjust every parameter. Why, to sell you stuff to adjust every parameter. Oh, your TA is low, add this. Oh, your pH is rising too fast, add that. Your vinyl will crack if you don't add this, something else will happen if you don't add that.
    Support the site
    Aug 2016
    Riverside, CA
    378
    I think that getting TA in the 80 to 100 range makes keeping pH in balance easier.
    May 2014
    Franklin, NC
    9,895
    Quote Originally Posted by Sammy2 View Post
    Actually, we find that in most pools 80-100 is actually too high. Many of us keep it in the 60-70 range
    Support the site
    Aug 2016
    Riverside, CA
    378
    Quote Originally Posted by tim5055 View Post
    Correct. I hit enter too soon while I was still thinking about it but for SWG pools it can be a little bit lower. I was editing my post the same time you were correcting it.
    My point being that TA is important if you want an easier time with pH not bouncing as much.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    There is no compelling reason whatsoever to check TA first. If anything, you should run pH and Chlorine before any other testing, because they are the ones which are time sensitive. If you grab your sample, then run your tests immediately (and you should) TA should not be a priority for first in line. It and CH can wait, and fight it out for last place in line. If you are adjusting pH with Pool Math, you need to know the TA number. While TA is important for various reasons it's not something you should put laser focus on or worry over too much. I'm not saying ignore it, but focus on controlling pH, and Chlorine first.
    Essential Links:
    Aug 2016
    Riverside, CA
    378
    I agree and the FC level is probably first of all because it is the only thing to KILL all the stuff that can at best turn your pool green and smelly and at worse kill you. pH is a very close second. This is why they're side by side on the OTO test kit which is all we used back in the day along with stockpiles of Sodium Hydrochlorite and Muriatic Acid always on hand.
