Results 1 to 13 of 13
Thread: New Pool Owner
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    New Pool Owner
    I bought my first house in march and it has my first pool. I'm in Naperville, a suburb of Chicago. I'm looking forward to opening the pool and spending most of the summer in it.
    Current & First Pool: In-Ground w/Liner 18'x37' 20,500 gallons
    1 HP Hayward Super Pump
    Hayward Superflex Filter EC75A
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,319
    Re: New Pool Owner
    M,
    Welcome to TFP... A Great resource for all Chicago pool owners...
    Enjoy your time with us...
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    Re: New Pool Owner
    Welcome to TFP! Make a pool signature and post a pic of your new pool. I've had mine just over a month. It's been TFP all the way and looks great. Do you have a test kit yet?
    Crystal
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    Minus the ladder.
    Currently
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New Pool Owner
    Welcome to TFP!
    I like pic A a lot better!
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    Thanks. I am having some trees removed next week. After that I'll start getting rid of the algae...
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    I see bubbling in my pump window when I go full skimmer with my 3 way valve. When it's 50/50 main to skimmer I don't see these agitation. Does that mean there is air being pulled in that line? I noticed my skimmer didn't have the basket or any kind of door or lid. I got replacements but I've been reading about some kind of valve that sits in the bottom? Any input would be appreciated.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: New Pool Owner
    Most likely your water level is too low and you're getting a vortex and drawing air. In that case it's either the pool level is too low or the weir (flapper) is stuck. You say you have no weir, so go take a look for a whirlpool and raise the water level.
    If your skimmer well has two openings, then you need a diverter. If your main drain has a dedicated line, that's not likely, so no diverter would be needed.
    You should have a basket in there to catch big stuff before it can lodge in the pipes and plug them. If it doesn't lock in somehow, a big river rock- bigger than the pipe opening -- will fix that.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    Thanks. I will put the basket and weir in and actually look at the skimmer when it's running and look for the vortex.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    There is only one line in the bottom of the skimmer and what looks like an overflow drain.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    What is the best way to determine what model number my Perflex filter is?
    MODELS: EC65A, EC75A
    Richard320's Avatar
    Jan 2010
    20,312
    Re: New Pool Owner
    Quote Originally Posted by Mkleisch View Post
    Lacking a readable label, it appears only by disassembly. The exploded parts diagram https://www.hayward-pool.com/pdf/man...C65A-EC75A.pdf shows the only difference to be the length of the fingers, er "flex tubes". EC 65 13 3/8, EC 75 16 1/4
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: New Pool Owner
    I also noticed a very small dimple in the EC75A bubble.
