Results 1 to 7 of 7
Thread: Solar Cover Kidney Shaped Pool
    Apr 2017
    Hart, MI
    3
    I have 25,000 gallon kidney shaped pool approximately 20X40. This will be my second summer with this pool and I am thinking about purchasing a solar cover for the pool. Has any one used 2 round covers for their kidney shaped pool? My husband is worried that that they will bunch together. I live in Michigan and don't heat our pool. I just want the pool to get warmer sooner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Solar Cover Kidney Shaped Pool
    Welcome to TFP!
    I cut my solar cover in half to make it easier to handle and there is no issue with it staying in place. There are pics of half of the solar cover on the pool in post #257 of my pool thread, link in sig.
    Dec 2014
    Rockville, MD
    78
    My pool (LINK) is somewhat similar to yours. The house came with a solar cover, that was never cut to shape. Last year, I did so, and found it a bit of a chore to take on and off. I was just thinking of cutting the cover in two to make it easier. I was planning to cut at the narrowest point, more or less having a shallow and deep end pieces. I expect the narrowing and unique shaped walls to keep the two pieces from wandering.
    Your pool's shape may do the same.
    Pool: 40x15ft "Mt. Lake" shaped plaster IG (30k gallons with Borates)
    SWG: Circupool Si-45
    Pumps: Hayward MaxFlo VS (SP2302VSP) + Booster Pump for Polaris 180
    Robot: Kreepy Krauly 830 || Filter: Pentair Tagelus TA-60D (Sand)
    Test Kit: TF-100 (with Speed Stir)
    Apr 2013
    Sacramento, CA
    2,769
    I have a weird shaped pool (my own design it matches my mind syas the wife) and my cover is in two pieces cut to shape
    I use the solar roller https://www.amazon.com/Solar-Roller-.../dp/B00IV3QKQG to roll it up.
    Mas985 has instructions on how to build your own DIY Solar Cover Roller
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    I have an irregular shaped 20x40 pool and cut my cover into (3) semi equal sections width-wise.
    Just used scissors then attacked a piece of 1/2 pvc pipe to each piece with zip ties.
    I did this to make it easier to float back into place.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Sunnymosmile's Avatar
    Oct 2016
    Raleigh, NC
    146
    Quote Originally Posted by blakeusa View Post
    This sounds interesting. Can you share a picture?
    16k Gallon, IG Vinyl, 16 x 34 x 25 Lagoon. Pentair Intelliflo VS2, ScreenLogic 2, Pentair Sand Filter, Colorlogic LEDs, TF-100, Speedstir, Pentair 920 Prowler (Rosie), and all wine is fine.
    Dec 2014
    Rockville, MD
    78
    I was thinking about the DIY solar roller last year but gave up when I couldn't find a source of foam core ABS piping.
    HINT TO ALL: True value hardware stores have it online and will ship it to local locations for you. (LINK) Is there any value in paying the extra $1/10ft for stuff rated schedule 40? Or upsizing to 2" for that matter?
