Results 1 to 7 of 7
Thread: Water seeping through new pebble Tec
    So we had water seeping through our Gunite and our pb told us that is completely normal, the pebble Tec was put in yesterday and this morning it still looks like water is seeping through.. My pb again is saying it's fine and the pebble guys will just need to cleanup, do the acid wash then start filling up.
    I'm concerned as to how the seeping ever stops and how I'll ever be able to tell once water is put in...
    Re: Water seeping through new pebble Tec
    Bump
    30,955
    Once the pool fills with water, the pressure will be equal on both sides of the pool wall and the water will have no reason to migrate into your pool. I don't see a problem.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, it will be fine and you'll never notice anything one way or the other. A pool evaporates 1/8"-1/4" of water every day. For a typical 16x32 pool that is 40-80 gallons per day. That spot of water is ounces at most. Also, plaster cures underwater. So, it doesn't start curing until after the pool is filled.
    Really appreciate the tips! Was freaking out for a sec.. Currently filling up.. Can't wait!
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    If the water was going the other way, I think I'd be a bit more worried.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,344
    Great looking pool! I love the colors of everything - really a nice feel when looking at it. What color is the pebble tec? Please post lots of pictures after its filled!
    You're not alone. That water seeping up through the plaster would have worried me, too. Interesting and great that it won't be a problem.
    Suz
    Suz~Cypress/Houston area~ My 2015 Pool Build. 24K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy; color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. TF-100, SpeedStir
