Thread: Trying SWG again
    Apr 2017
    Murphysboro, IL
    3
    Angry Trying SWG again
    Where do I start?
    I presently have an aboveground steel pool that was chlorine but a year later reto-fitted for a Hayward aquarite SWG. One end is partially in the ground (maybe 1ft.). It's about 10 yrs old and is pretty much shot from corrosion. I'm an electrician so the pool is grounded and bonded. After I had the pool installed I built a treated wood deck around the perimeter of the pool and stain every 2-3 years while replacing the treated deck screws it was built with. I am getting ready to replace the pool and would like to again use a chlorine generator as my sanitation method (my wife loves it!). My question is:
    What can/must I do to discourage the problems with corrosion I had with the previous pool and deck? Would an aluminum pool by itself rid the problems of corrosion? A pool installer has told me that "super" grounding the pool even if it's steel would greatly reduce this problem but common sense tells me salt will still win this battle. Will a composite material deckboard keep me from constantly having to replace the screws? I'm not familiar with the fastening system that these materials use. Any knowledge and help would be greatly appreciated. Thanks
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Trying SWG again
    Steel will corrode so will aluminum. Resin will get brittle and often times resin pools have a lot of steel in them. No above ground pool will last forever.
    Aluminum "should" be the longest lasting option of the 3. The more expensive resin and steel pools tend to have better corrosion protection coatings and should also last a long time.
    As for deck screws you can switch to stainless. The coated deck screws these days are under constant attack from the pressure treating chemicals in the wood and anything you throw at them from the outside. Composite decking still uses plain steel screws and tend to have pressure treated framing underneath. If you go to composite do so for the look not the life of the screw.
    As for the salt required for a SWG accelerating corrosion it's probably minimal at best. The chlorine in the pool is more harmful to the steel than the low levels of salt in the water.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2017
    Murphysboro, IL
    3
    Thanks CJ,
    My thinking at this point is to go with aluminum and replace the deck screws with the stainless screws you recommended. Probably going to replace the deck boards while I'm at it ... they aren't in the best shape either.
