Thread: Unlevel pool 488cm (16 ft)
    May 2016
    Soinaste küla, Ülenurme vald,Tartu-Estonia
    8
    Hi,
    This will be my second year with my intex pool 488cm x 122cm (16'x48'').
    Last year it was unlevel about 4,5cm (should be about 1,77 inches, sorry I'm from Europe ,we use cm ;-D )
    The ground it's very strong (no sand) and it didn't move at all.
    Now after winter I measure the water level and it's the same about 4,5cm difference, so
    things didn't went worst in one year, and I suppose will remain the same.
    Question: is there some point to empty the pool and level the ground or I can be safe and quite like this?
    I think everything it's fine....but some suggestion would be good!
    I add pictures of last year:first pic is the side where the water is more "low" (so high floor level)...where is ladder is more deep water (low floor level)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Unlevel pool 488cm (16 ft)
    We recommend no more than one inch out of level from lowest to highest point.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    On a 16ft pool 4.5 cm is a lot to be out of level. You are putting a lot of added stress on that side of the pool. No more than 2.5 cm out of level is recommended. Less than 1 cm is ideal.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    8
    Thanks for your messages!
    So it seems that you suggest to level the ground....
    I was planning to don't do it, as last year I made all the season with that difference (4,5 cm)
    and now after one year I see that swimming pool didn't sink nowhere, so I was hoping to don't do the job.
    But if you think it's worth to do, I suppose I have to do it!
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Your pool looks pretty level form the picture, but if it is out more than 1" (2.5cm) you run the risk of failure. You are looking at over 40,000 lbs (sorry, 18,000 kg) of water. I wouldn't risk it. Better to be safe than sorry.
    Good luck!
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    May 2016
    8
