Thread: What should I do?
    Apr 2017
    Virginia Beach VA
    1
    What should I do?
    Test results for a SWG 13500 rectangle pool in full sunlight. Running the SWG at 25%. The water is crystal clear and all the equipment is running fine. The local pool store is telling me I'm not generating enough chlorine. They are saying to raise alkalinity and stabilizer and bring the pool to schock level. What are the normal limits for alkalinity and stabilizer for my particular pool. It's been 75 degrees the past couple of days but I do not see any algae anywhere in the pool. Thank you.
    Alkalinity- 57
    PH-7.6
    Calcium Hardness-184
    Total chlorine-.35
    Free chlorine-.15
    Chlorine stabilizer-21
    Borate-38
    Salt-3500
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,897
    Re: What should I do?
    I am going to share a set of links with you. It is for pools that are new to people or people new to TFP:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small!
    All of our ways are based on having our own test kit. The one I like the best is in my siggy below. It has more of the regents we use on a daily bases. I know the Pool $tore will test for free but we have found they get it wrong more than right AND they are in the business of selling stuff. Here at TFP we are here to make pools sparkle and people smile!
    How long have you had this pool? I would go get some chlorine/bleach (same stuff just different %). Make sure it is plain, no pretty smells bleach to get your FC up. We have found a SWG is not good for getting the FC up. That needs to be done with liquid chlorine/bleach THEN the SWG should be able to help keep it where you want it to be.
    I look forward to seeing your pool!
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    I agree that CYA needs to be raise to 70-80. TA is fine. CH should also be raised to 250.
    More here, Pool School - Water Balance for SWGs
    Please add your pool info to your signature, more here on how to do that, Pool School - Read This BEFORE You Post
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,257
    Gap,
    Welcome to TFP... A Great resource for all SWCG pool owners...
    Even the dreaded Pool $tore can't be that far off on your FC level, so it looks to me like your SWCG is not producing the chlorine you need.
    You say the SWCG is set to 25%, but that is only part of the answer.. How long is the pump running? The SWCG will only work if the pump is on.
    You can test to see if the SWCG is working, one of two ways..
    The quick way, which gives you a yes/no kind of answer, is easy.. Take a sample of your water, away from any return port. Measure the FC level and record. Turn the SWCG up to 100% and turn the pump on. Put an empty plastic bottle right in front of the pool return closest to the equipment pad and capture the water coming out of the return. Measure the FC/chlorine level and compare to your first test. If the SWCG is working you will notice a significant difference. This test can be done with any cheap test kit as accuracy is not important.
    There is a much more accurate way to test your SWCG's output, but it requires an accurate test kit, like the TF-100 or Taylor K2006C. Let me know if you are interested and I'll provide the test procedure.
    Thanks for posting,
