Results 1 to 10 of 10
Thread: Intelichlor ic40 help
    Apr 2017
    Houston tx
    3
    I have a intelichlor ic40 swg it's saying clean cell. I have cleaned the cell multiple times and when I plug it back in it will read no errors. By the next day it says clean cell again. Is there something else that could be causing this?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,270
    Re: Intelichlor ic40 help
    M,
    How old is the cell?
    What color lights are on/off/flashing?
    What is the salt level and water temperature?
    Support the site
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    The cells don't work right at water temps under 70- degrees. They are calibrated for that temp....
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Cold water cutoff is about 52 degrees Fahrenheit. The Intellichlor does have temperature compensation. Pentair recommends that the unit not be used under 60F.
    At 60F, or above, the cell should work as long as the salinity is sufficient.
    What is the cell version?
    Support the site
    Apr 2015
    Waikoloa Hawaii
    13
    Press and hold the increase output button for about 3 seconds (display lights will flash) and the release the button. After the flashing lights the output indicator will illuminate 1-5 lights. This will give you a rough indication of how many hours are on the cell. 1 light 2000+ hours, 2 lights, 4000+ hours, etc.
    I have yet to see an IC40 still working after 6000+ hours (not saying it can't happen!).
    The flow/temp sensor can also go bad and give that "check cell" light. They are replaceable and certainly less expensive than a new cell.
    Apr 2017
    Houston tx
    3
    Not sure how old the cell is. Salt level is 3400 and water temp is above 70.
    There’s a sticker on the bottom. What information does that show?
    Support the site
    Jul 2014
    Bedford, TX
    9,270
    M,
    Did you try the trick/test that HawaiiPoolguy suggested above? Press the "more" button for 4 seconds and release.. This will tell you how much of the cell life has been used..
    Apr 2017
    Houston tx
    3
    No I haven't tried that yet I will try that tomorrow.
