Results 1 to 14 of 14
Thread: Pool Cleaner that climbs steep inclines
    Poolipop's Avatar
    Sep 2014
    Fayetteville, NC
    33
    I have this type of pool with fairly steep inclines. My budget is around $500, but if $1000 gets me something much better, I am open to it.
    Any suggestions to a robot or cleaner that can handles those 60 deg inclines in the deep end?
    26,000 Gallon IG (in ground) Vinyl Pool
    Filter: Hayword S220T Sand
    Pump: Hayword (1 hp)
    CircuPool Si-45 Plus SWG (Installed myself)
    TF-100 Kit w/ magnetic stirrer
    Mar 2017
    NJ
    10
    Re: Pool Cleaner that climbs steep inclines
    Quote Originally Posted by Poolipop View Post
    I would check out the dolphin S300 or s300i
    Poolipop's Avatar
    Sep 2014
    Fayetteville, NC
    33
    Is this comparable to the S100 or S200:
    Dolphin Nautilus Robotic Pool Cleaner with CleverClean | 99993116-US
    Is it worth the extra $$ to get the S300 type if I just care about cleanliness
    JoyfulNoise's Avatar
    May 2015
    14,081
    Based on this chart - The Truth About Pool Cleaners: What Your Pool Store Isn’t Telling You | Sunplay
    Dolphin Nautilus (2017 and Later) = Dolphin Cayman = Dolphin Active 20 = Dolphin S200 = Pentair Prowler 920
    Basically with robots, you have to figure which features you absolutely need and then find out what the suppliers in your area are stocking. Maytronics pretty much supplies the entire robot industry with various models and platforms creating their own product line as well as manufacturing the brand name labels for major pool equipment suppliers (i.e., Pentair's robot is actually made by Maytronics). So there's often not much difference in the name...
    Also, I would suggest you buy local from a brick & mortar shop so that you have a local repair option. Many people will sometimes try to save a hundred bucks or so buying online and then have to ship their robots out when trouble strikes. I recently went with an S300i for the options and because the shop I bought it from is an authorized Dolphin repair shop and is 3 miles from my home.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I think you would be happy with the S100 or the Doheny's Saturn.
    Poolipop's Avatar
    Sep 2014
    Fayetteville, NC
    33
    Quote Originally Posted by pooldv View Post
    This would be my first pool cleaner and due to the complexity of the structure of my pool, I want to make sure the robot can clean most of the complex surface area. There is not much flat area in the deep end, so I need something that can understand lots of inclines.
    Does the S100 understand the layout of your pool or does it just run a pre-programmed pattern?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    The S100 (same as Dolphin Cayman) does have intelligence. See the following link. http://www.caymanrobotic.com/
    Note regarding the above model listing, there are some inaccuracies in it. Dolphin Nautilus/Nautilus Plus 2017 models are not twins to the S100 or S200. Dolphin Cayman = S100= Dolphin E10= Doheny Saturn. S200=Active 20, Doheny Discovery=Dolphin Triton Plus. Among others.
    S100 has one brush and one year warranty, S200 has two brushes and two year warranty. Not much else is different.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    14,081
    Have you called around to local stores and asked about a demo model? At least two of the shops I talked with local to me were willing to let me demo the unit I was interested in for a week to see if I liked it at no cost. It might help you decide.
    Matt
    Poolipop's Avatar
    Sep 2014
    Fayetteville, NC
    33
    I will take some action and report back. It could be a couple weeks at this point. Thanks for the help.
    Poolipop's Avatar
    Sep 2014
    Fayetteville, NC
    33
    OK, with all the advice here I ordered the Active S20 (S200)!! So excited. Thanks again.
    DFW, TX
    24,974
    Woohoo!
    May 2015
    14,081
    You're going to love the robot. Congrats on the purchase.
    Matt
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    Welcome to the club!
    Mar 2017
    NJ
    10
    Great feedback on this tread just purchased the s300 and Absolutely love the product!!! You
