Thread: SWG recommended run time and output
    Apr 2016
    Murfreesboro, TN (Middle TN)
    106
    Hello all. I have a Hayward Aquatrol thay I just installed. Pool info in the signature.
    My chlorine is running really high fc=10+ since I installed the SWG. I started at 100% output running pump 8-5 and now I'm down to 25% output. I just reduced pump run time by 2 hours. I'm wondering how long I should wait before adjusting again?
    Couple of questions.
    How long does it take to realize a change in chlorine output or pump runtime with CYA of 80?
    Are there some estimates on what I should shoot for on runtime and chlorine output?
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, SWG Hayward AquaTrol TCell 15, Test kit Taylor TF-100
    Murfreesboro, TN
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: SWG recommended run time and output
    I would turn off the SWG for a day or two to let the FC drop. You will probably lose less than 2 ppm per day right now. Somebody made a SWG runtime calculator but I can't remember who at the moment. With cooler weather right now I would think 20-30% for 6 or 8 hours is good.
    Apr 2016
    106
    Will give it a try. Didn't even occur to me to just turn the chlorine off. Thanks!
    Murfreesboro, TN
