Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: New 20 x 48 AG
    geegaw's Avatar
    Aug 2015
    Texas
    331
    New 20 x 48 AG
    Help with figuring how much bleach I need at start up?
    Everything INTEX, 20 x 48 , AG, 8362 gal. although its only 90%full. well water, pump 2500gph intex, bleach 10%, and Taylor test kit.
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Re: New 18 x 52 AG
    Quote Originally Posted by geegaw View Post
    Sent from my LG-AS330 using Tapatalk
    That is what Pool Math is for.
    Enter your pool's gallons up top, then go to the FC section (right under gallons) and enter the current FC in the NOW column, and your desired target in the TARGET column.
    Be sure you enter the correct strength for the bleach, either 8.25% for laundry bleach, or 10% or 12.5% for pool $tore bleach.
    Remember, your FC is based off of your CYA
    PoolMath
    Chlorine CYA Chart
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    17,340
    Re: New 18 x 52 AG
    Hello and welcome to TFP! With new water at start-up, we advise keeping free chlorine (FC) levels on the low end until the appropriate amount of stabilizer/condition (CYA) is added to the water to protect swimmers/equipment. A pool your size wouldn't take much - about 2-3cups or so.
    If you haven't done so already, please review the TFP Pool School link (top of page or in my sig) and the Recommended Chemicals/Levels links as well. Of course we hope you have a TF-100 or Taylor K-2006 test kit or else everything is guesswork. Pools react quickly to poor testing so be very careful about that. Hope that helps. Nice to have you with us.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    Thanks. I just have a hard time rembering. But once I get started I shouldn't have to bother anyone. But thank you.
    Jun 2014
    17,340
    Re: New 18 x 52 AG
    No bother! Ask a question and you'll get more replies than you every wanted. We're all hanging around happy to help.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    Thank you.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    Thank you very much ! I will be starting It up within a month or so.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    Hi I have found a great deal on 20 x 48 ag ultra frame inter pool...what kind and size pump should I buy to upgrade tube tiny and that comes with it? I thought about sand but have read a lot of troubles come withthst one.
    Jun 2014
    17,340
    Re: New 18 x 52 AG
    Much will depend on what you want to spend and what you want to clean. While you have your concerns about sand, many get them because they are so easy to clean - basically turn a valve to backwash & rinse. DE filters are the same, but then you have to maintain the grids with DE and you may not want to get into all of that. Cartridge filters are fairly easy, just pull them out occasionally and rinse them off. But for your new/proposed pool size of about 28K, I would recommend a 420 sq ft size filter (has 4 cartridges) which allows for more time between cleanings as long as the water is TFP clear. I found the smaller 320 sq ft filter HERE just so you can get an idea of the price. But even if you go sand, try to go a little larger for better efficiency. Also keep in mind that the pump you chose will play a part in that as well to ensure the match-up properly.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    Thank you !
    My thread says 18 x 52 but we found a deal on 20 x 48 so we got it instead. Not sure how to change thread title.
    Anyways we got it up may 7th.
    Its beautiful crystal clear is give it a 10!
    Readings are today :
    Fc 4
    PH 7.5
    CC 0
    TA 60
    CYA 38
    Jun 2014
    17,340
    Re: New 20 x 48 AG
    I updated your thread title for you. As for your test results, those are overall good numbers. Make sure to test the FC each day to ensure it doesn't dip below 3. Based on your CYA, the ideal FC range is between 5-7. The TX sun is coming, so FC will drop a little faster each day. Soon you may even elect to increase CYA to 50 for more protection from the sun. Just depends on how much sunlight your water receives each day. Have a great day.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 20 x 48 AG
    I have thousands of very tiny yellow bugs that survive and live in my pool skimmer and filter pump....how do I get rid of them? My water is resding great! Even over night test is awesome.
    Fc 5
    Ph 7.5
    Ta 70
    Cc 0
    Cya 40 ( just added yesterday how long until Cya is settled enough for true reading ?)
    Jun 2014
    17,340
    Re: New 20 x 48 AG
    Texas bugs are something else. We get all types. The best thing I use is my skimmer sock. For that I use a 1 gallon paint strainer net and slip it inside my skimmer basket. It does a great job catching those little buggers. The only time I can't do much about bugs is when the wind is blowing in the opposite direction as my skimmer.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    The rain is great but pool readings not so good.
    Fc 6
    Ph 8.2
    Ta 70
    Cya 40
    That was before I added MA yesterday morning.
    Last night readings.
    Fc 6
    Ph 7.2
    Ta 50
    Cya 30
    Where do i go from here ?
    I added 30 oz baking soda last night
    And 13 oz bleach
    Was going to retest this morning and add Cya ?
    Im using Taylor test 100
    Is there a way to lower ph when needed and noteffec ta so much or vice versa ?
    May 2017
    Vernon hills
    30
    Re: New 20 x 48 AG
    You can increase ph and not increase TA by aerating the water (point return jets up so water breaks surface of water). To lower ph use MA but that will decrease TA as well.
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 20 x 48 AG
    Thanks!
    My new readings look kinda like my last ones due to almost 10" of rain in 2 weeks !
    Fc 6
    Ph 7.5
    Cya 40 still tryingt to get it to 50.
    Ta 70
    Ch 25
    Cc 0
    I add 19-32 oz of 8.25% bleach each day.
    I add MA ad needed to drop it to 7.2 because the rain brings it back up in a few days.
    Will recheck Cya Tuesday.
    Water is amazingly crystle clear ! We had 7 kids in the pool for 2 days all day long each day!
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    How do i keep my ph in check better. I get it down and in a day and a half its back up.
    My readings are
    Fc 6
    Ph 8.2
    Ta 70
    Do I need to up my TA to 80?
    It wad 80 but with all tube acid I have to add I can't keep it there.
    Im now using dry acid due so much wind and I just wanted to see if there was a easier way to get ph down. It works great but just like with MA ph jumps back up in 24 - 36 hrs.
    Please help me figure this out.
    Thanks in advance
    May 2012
    Montville NJ
    637
    Re: New 18 x 52 AG
    TA will help to buffer your pH (keep it stable). Your TA could be another 10 to 20 ppm higher. Don't go too high though, if you goo too high with TA it will cause your pH to drift up.
    Don't worry too much about your CYA right now. CYA can take a few days to fully dissolve and disperse. I keep my around 40 myself, and I add about a quart of bleach a day with pretty much full sun.. Suits me just fine. Keep in mind that my pool is over twice the volume of yours, so that would be about 2 Cups a day for you.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (new June 2015)
    Filtered 4 hours per day
    Hayward AquaTrol-RJ SWG
    Zodiac Wahoo
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 18 x 52 AG
    I end up adding 20- 28 oz of bleach a day. My ph is always drifting up but did better last 6 days.
    Thank you for your help!
    Fc 5.5
    Ph 8.2
    Ta 80
    Cya 50
  20. Back To Top    #20
    geegaw's Avatar
    Aug 2015
    Texas
    331
    Re: New 20 x 42 AG
    Not sure where it how to post questions?
    My readings
    FC 18.5 SLAMMING FIRST DAY
    PH 6.8
    TA 80 after adding baking soda
    CH 25
    CYA RAISING NOW TO 40
    TEMP 78
