Thread: Pool Cleaner Recommendation
    Jun 2016
    Oldsmar, Florida
    7
    Post Pool Cleaner Recommendation
    I have a 15,000 gallon pool with pebble sheen blue surf. I am looking at the Dorado pool cleaner. Can anyone tell me if this is a good choice for an pebble surface?
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    Re: Pool Cleaner Recommendation
    Are you specifically looking for a suction side cleaner, or have you considered a robot?
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jun 2016
    Oldsmar, Florida
    7
    I am looking for a suction side unit.
    Thank you.
    For the mat type I like the Zodiac G3, & T5
    The G3 runs cheap cleans well and never gets stuck on floor to wall transfers, but it doesn't make it to the shallow end very often.
    T5 is a tiny bit larger more aggressive per watt, but can get stuck a bit easier on low power. It gets to the shallow end a lot.
    Creepy Kauleys aren't bad but get hung up more in my pool than the zodiac brands do.
    Of the wheeled type I like the poovergnugen.
    For tracked units I like the zodiac MX8 and 5
    The MX 5 & 8 actually scrub the pool floor actively with the brush kits.
    UD
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
