Thread: Opening pool and discovered red blood worms in the water, many, drain or no drain?
    Jun 2016
    Pittsburgh, pa
    369
    Took the cover off the pool, which was mostly off anyway, it had broken loose about a month ago.. began to clean out the pool with a net only to discover these half inch or so tiny red worms all through the water, maybe 100 or so, guessing, very hard to see.. from what I read they are larvae for flys or some other type of insect.
    From what i can see online, it may or may not work to just shock the pool and kill them, or possibly needing something called blu52?
    Either way, its disgusting enough that I'd like some guarantee they are gone once the pool is fully open.. i guess the combo of the chemicals and filter should work?
    Any thoughts on this, or am I better off draining and cleaning and starting again..
    Thanks in advance
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Opening pool and discovered red blood worms in the water, many, drain or no drain
    Don't drain, and don't add that product. I have no idea what it is, and if you don't know it will work, or what is in it, you should never add it. Oh and tell us about your pool. Please place the pool details in your signature section. How many of these things are in your pool?
    I imagine Chlorine will kill them, so tell us more. Never mind on the number, I missed that sorry. So, if its 100 or so, no way would I drain. We used to feed these to aquarium fish, and 100 isn't many if it's anything close to the same type, and it sounds like they are.
    Essential Links:
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    175
    Put a hairnet in the basket and vacuum them up? Catch them with the net?
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by Patrick_B View Post
    I imagine Chlorine will kill them, so tell us more. Never mind on the number, I missed that sorry. So, if its 100 or so, no way would I drain. We used to feed these to aquarium fish, and 100 isn't many if it's anything close to the same type.
    I added the info to my sig, thanks for the tip and response.
    Its your basic ultra intex 18x52 pool with sand pump and also the salt water system.. i began filling it back up to the levels so i could turn on the pump system and add more salt for the salt water generator to work.
    I also have the basket side filter, where i have to put the cap to plug one of the two outlets so the basket gets most of the strength during most normal filtering. Currently i got a great deal of the leaves out of the pool except a boat load still on the bottom along with dirt..
    Before i spotted these buggers i was anticipating either just using 2 bags of shock (i had on hand before i went salt water) or maybe 2-3 jugs of chlorox from the dollar store, or both.. the water is pretty nasty, though not too brown, just sediment i think.
    On the subject of the worms..
    What was meant by hairnet on the basket and vacuum? Meaning the hose vac attachment? i'd imagine just using it alone might be worth a shot without any mods..
    Either way I just hope that even if they arent visible they are truly gone after all this.. the thought of them in there, being so small is rather nasty.. they tend to slip right through the net is the other issue, they are tiny.
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Anything with 'blue' or 'blu' in the name likely contains copper and you don't want it in your pool. Unless you like 'green' hair, that is.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2016
    Hillbillyville, MO
    175
    I put a hairnet over the basket in the skimmer. It catches all the small stuff but I have a paper filter, not sand, so I try as best I can to protect it and hair nets are super cheap and work well.
