Results 1 to 12 of 12
Thread: Chlorine not showing up in SWG.
    Feb 2017
    Tampa
    25
    Hello
    We just got the okay to add salt to our resurfaced pool and also added Chlorine. I added both the salt 640 pounds, and Chlorine 110 ounces of 10% bleach on Friday. Today, I tested and the salt is 2100 ( I already knew I would need more salt) but the chlorine is still not showing up. The pool pump has been running 24/7 since the salt was added and the SWG was turned on yesterday.
    Not sure what I might be missing? Does the chlorine take a while to show up? I will be adding muriatic acid for the PH today but am not sure if I should add more chlorine.
    TA is 120
    CYA = 60
    PH is 8.0
    CH = 300
    Thanks, Tom
    40x24 round/kidney shaped, IG 28k gal, Built in 82, 2017 Resurfaced pebble tec. Hayward DE Filter DE2420 1.5hp, Hayward SP0710XR50 Vari-Flo Pool Valve, marathon motor 1.00 HP, 1.50 SF, 1.50 THP, Circupool SJ Series 40,000 and Dolphin nautilus pool cleaner.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Chlorine not showing up in SWG.
    The SWG won't produce CL if the salt level is too low. A warning should have shown on the display. I would continue to use liquid CL until you have the salt level correct.
    Mark
    Feb 2017
    Tampa
    25
    Added the additional salt yesterday afternoon and also added muriatic acid to lower the PH which was 8.0, and liquid bleach 10%. Still not showing any chlorine when testing today. Not sure how long until I should see the chlorine levels increase?
    mas985's Avatar
    Pleasanton, CA
    11,987
    How much bleach did you add?
    How old is your test kit?
    At this point you may have something consuming all of the chlorine. I would bring it up to at least 10 ppm with liquid chlorine and then see if you lose anything overnight to warrant a SLAM.
    Mark
    Feb 2017
    Tampa
    25
    Added one gallon of 10% bleach, Test kit is new Taylor 2006, also had the pool shop check and they read no chlorine, Which try adding liquid chlorine again and check again.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Each gallon of bleach will add only 3.5 ppm to that size pool so I would add at least two gallons but if there is something growing, it will take a lot more than that.
    Mark
    domct203's Avatar
    Jun 2015
    CT
    3,900
    How long after adding chlorine do wait to check FC? An hour later, 12 hours later, next day?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    mas985's Avatar
    Pleasanton, CA
    11,987
    An hour should be sufficient, pump running of course.
    Mark
    domct203's Avatar
    Jun 2015
    CT
    3,900
    I was asking the OP.....
    Dom - TFP Guide
    Feb 2017
    Tampa
    25
    I've been checking about 12 hours later. Today I checked an hour after adding 3 gallons of 10% and I have a lot of FC. I tried testing the exact amount but is was using too any drops. I will see how it does overnight.
    Thanks, Tom
    mas985's Avatar
    Pleasanton, CA
    11,987
    Sounds like it is SLAM time.
    Mark
    Feb 2017
    Tampa
    25
    Thats what I am thinking. Showing no FC 7 hours after I tested and showed plenty. Water still looks crystal clear.
