Thread: New Guy
    Cedar Island NC (Outer Banks)
    84
    New Guy
    Been following Phyllis's thread. Think I'm getting close?
    40x20 Splash above ground, 29,000 gallons. K2006 Test Kit. Pumping 24/7
    Been hammering it with chlorox and vacuuming to waste...volume of algae coming out almost gone. Pool starting to get a little bluish and can almost see second step. We're on the water with lots of wind.
    at 0840 this AM
    FC = 18
    CC = 0
    TC = Don't see how to do this with the K2006
    pH = 7.4
    T/A = 230
    CH = Gave up after 60 drops!
    CYA = 40
    Temp = 74
    Am I on the right track? Keep the FC high and vac to waste until no green and have patience? (And stay out of the pool store)
    Thanks! Steve
    Cedar Island NC (Southern Outer Banks)
    Splash Super Pool (40x20)
    29,000 gal; AG; Sand Filter; 1.5HP pump. Use the cosmic Taylor Test Kit
    New Aquarite SWG w/T-15 cell; New Dolphin Supreme M4 Robot cleaner
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: New Guy
    have you read pool school also? you can find how to do TC in there.
    pool-school/swimming_pool_definitions_abbreviations
    also, there is a quicker way to do the CH test that is less precise but helps you get a picture of what's in there without using so much reagent (mine ended up being 625). let me try to find that post and I will edit this one with the link.
    ok, here is the quote from waterbear:
    Quote Originally Posted by waterbear
    with high CH you can do the test this way--10 ml water sample, 10 drops of first reagent, 3 drops of indicator, and then when you titrate each drop of titrant is 25 ppm CH instead of 10 ppm. You lose some precision but when you have very high calcium like yours it really does not matter that much if your CH is 620, 625, or 630 ppm (or even 600 or 650!)
    the post can be seen in this thread: liquid-chlorine-vs-swg-and-skin-irritation-t11950.html
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: New Guy
    There is no test for TC. It's just FC + CC. So, FC=18, CC=0, TC=18.
    Yep, you've got the right idea. The guidelines we use to determine if you're through shocking yet is :
    (1) Overnight FC loss test is 1 ppm or less,
    (2) CC 0.5 or less
    (3) Water is clear and sparkly
    After you get through shocking we can address your high TA if needed and once you figure out your CH we can advise you on how to manage the water to prevent calcium scaling. You're on the right track though.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    84
    Re: New Guy
    Quote Originally Posted by reebok
    Thanks! I had done the school and was going back to see about TC (I'm a geezer and forgot) .
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: New Guy
    Steve, welcome to TFP!!
    Sounds like you're on the right track Thanks for posting the test #s One thing you're looking for is cl loss overnight - do you have the fc from last night?
    TC is simply fc + cc so, your tc = 18 (18fc + 0cc)
    With the CH test, you can fill the tester to 10 ml add 10 drops of the buffer and use 3 drops of the purple indicator then each drop of the R0012 will equal 25 ppm instead of 10
    Luv& Luk
    -Ted
    84
    Re: New Guy
    Didn't do an overnight because I was still vacing green stuff. I think I've almost got it all so will do so tonight. My guess is I lost about 2ppm since I used the Pool Calculator to get it to about 20ppm but I did not check it after adding the chlorine. We are right on the water (Sound on the Outer Banks) and have had a lot of wind.
