Thread: Raised Spa draining into pool when pump is off
    Hi Everyone,
    I am having issue with my spa water draining into my pool when the pump is off. After further research, it seems like my only solution is to install a check valve. However, with the way my plumbing is currently constructed, I will need a check valve that can be installed vertically with "downward" flow. But I have not found any check valve that can do that. Most valves I found stating that they have to be installed horizontally or vertically with upward pressure. Has any one of you ever encounter any situation like this? Would you please let me know if you found a valve that worked with downward pressure? Thanks
    Below is a picture of the return pipes for both my spa (left) and pool (right):
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Raised Spa draining into pool when pump is off
    Essential Links:
    TxBwana's Avatar
    Mar 2017
    Plano, TX
    73
    Before you do that, you might want to check to make sure the o-rings are all good in your valves... seems to me when we had that problem once, it was an o-ring that had gone bad.
    15k IG gunite, built 1999, RiverBend Sandler, attached spa, Dolphin S200, Pentair Triton II sand filter, Wet Edge Prism Matrix in Constellation with extra ocean shells handcast, Pentair MasterTemp 400, my remodel
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,882
    The Pentair and Jandy style check valves are often incorrectly mounted in that orientation but work just fine. That looks to be about your only option without getting too crazy with replumbing.
    -Brian-
    Pool/Spa, Pentair Equipment
