Results 1 to 19 of 19
Thread: Looking for a liquid chlorine injector for a 2300 gallon pool.
    May 2015
    Central Illinois
    44
    Hi folks,
    Getting ready to open the pool. I have a very small in ground pool and I have been adding chlorine bleach manually for the few years I've been maintaining the pool. I have read about the "liquidator" but can it be dialed back for my little pool?
    Thanks in advance!
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    Mar 2015
    Sugar Land , TX
    446
    Re: Looking for a liquid chlorine injector for a 2300 gallon pool.
    Stenner pump would be perfect ! Search the forum, plenty of info
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    May 2015
    Central Illinois
    44
    I went to the Stenner website and found no less than 18 different pumps. It looks like the Econ LD is the only one with a low enough rate to not overdose my pool. It lists .04oz. per hour - 8.1oz. per hour. Or about 1oz. - 194oz. per day. I think I put in about 1.5 cups per day, or less... So you just put a small hose into a gallon of bleach and the other end of the pump a small tube into the skimmer?
    Oct 2007
    Parkland, FL
    753
    why not just a small salt generator?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    30,964
    2300 gallons in a partially covered pool? What are your daily chlorine additions now......maybe about 8 oz.?
    May 2015
    Central Illinois
    44
    Robl45, they put one in when it was installed and it would over chlorinate and error out. They told me it was the smallest one available and took it out. I also hadn't considered backwashing salt water on my hillside full of old growth oak trees.
    Actually my chlorine demand is 4 ounces per day, just looked it up. I did some research and found I can get a normal size pump and run it for a short time once a day. If I get a 10gpd pump it will need to run 4.5minutes per day. If I get a 3gpd pump it will need to run 15 minutes. If I did my math right... I looked up the Stenner Pump 45mhp10 and found it for $300. I just need to find a timer that controlls to the minutes. Or build one. Any ideas?
    Oct 2007
    Parkland, FL
    753
    I'm pretty sure they make SWG for jacuzzi's and such, I'm sure there is a size that fits. Also a cartridge filter would eliminate the backwashing. I don't have any ideas on a timer that would work in this application. I do remember that my cousins had an indoor pool which is basically what this is and used UV light intead of chlorine, maybe that would work in this case.
    Quote Originally Posted by Fungi View Post
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    You can't rely on UV alone. It's entirely up to you, but I think trying to automate Chlorine feed in this pool by any means is going to be more trouble than it is worth, and difficult to dial down that far.
    Are you gone a lot for extended periods?
    Essential Links:
    Oct 2015
    San Diego, Ca.
    808
    My Liquidator developed salt fakes from the chlorine. The salt flakes jammed up both float valves within 4 days. After cleaning, they promptly returned. I introduced the Liquidator to the dumpster.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mar 2015
    Sugar Land , TX
    446
    Most of us have a 15 gallon tank for the bleach ( you would not need that big). We then tap a hole in a return pipe at pad to screw in the injector ( comes with Stenner ). You can use a Intermatic timer to control it.
    May 2015
    Central Illinois
    44
    robl45, no thanks to swg. I do have a UV thingy on there due to low UV from sun.
    patricknb, that makes no logical sense whatsoever. A timer that can be adjusted accurately to minute intervals are available and there is no reason to think because it's smaller it would be more difficult to control. I usually put in 1.5 cups every third day. It is easy to forget was it two days ago or three... So yeah, I'm happy to just check the chlorine daily and make any small adjustments as needed.
    philo, yeah the liquidator is out.
    rphpool, thanks that's the direction I was going.
    thanks all for the comments. They have helped me immensely.
    Jul 2015
    Central Valley CA
    1,166
    A nice upgrade for the Stenner timer and less expensive than Intermatic is a WiOn or WeMo plug adapter or switch they are WiFi controlled by a smart phone app and both are extremely programmable pick the day or days of the week and as many run times as you like down to the minute. They also have a count down timer if you want to do a one time addition. I have 2 WiOn's for my Stenners
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Ellington, CT
    307
    I'm going into my 5th season with a Liquidator and am very happy with it. I have had no problems with "white stuff" or "salt flakes" clogging my lines. I do think you can make it work with your pool. I recommend that you get a pinch valve to control flow and use a low concentration of chlorine (6 to 8.25%). Dial in the daily dosing using the flow using the pinch valve and length of time that you run the pump.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, Maytronics Active 30i cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Check Lockewell.com for Stenner pumps. The most common fixed rate models are 221.00 right now. You don't need an adjustable pump because you can use a timer to run it for the desired number of minutes per day.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    May 2015
    Central Illinois
    44
    Thanks so much GDN. I'm getting the 3gpd one right now. This is quite the surprise!
    Atttech-2 interesting concept, but I'm not a smart phone sorta guy. lol Just wait till someone in Russia is adjusting your chlorine levels.
    I found this little gem for $4.55. You set the real time, the on time, and the off time, in hours/minutes, done. Minute resolution for a 15 minute process gives me room for adjustment. I've used these type of pc boards from China before. They have all worked well. A good coat of conformal coating and it's ready for outdoors use.
    12V Relay Multifunction Cycle Delay Timer Module Switch Real Clock Control Time | eBay
    May 2015
    Central Illinois
    44
    So I received the pump and it was a breeze to get working. I drilled a 1/4" hole in the lid and a tiny hole for ventilation. I pushed the line into a full bottle of bleach and connected the line to the pump. I used a drain port on my old puck feeder to put the injector. Worked perfectly. I ran the pump for about 5 minutes to get the fluid moving, then connected the line to the backflow preventer/injector thingy. Still waiting for the cheap china timer, am currently using a all in one unit. So far working great. I have it set for 15 minutes at 11:00 am. The equivalent of 1/2 cup. The gallon of bleach will last 30 days give or take.
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Very nice. Glad you got it set up and working. Just one less thing to worry about - once you get that timer in.
    Greg -
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Hey, that's a pretty cool set up! Your spare jug of bleach will hold its strength better if you move it to the laundry room.
    May 2015
    Central Illinois
    44
    Hi pooldv, Yes it's still early in our season, days are in the 60's so not worrying about bleach storage yet. I plan to make an insulated cover for the bleach to keep it in the shade and allow it to be cooled by the concrete.
    Hi GDN, yes it's the best $200 I've spent on the pool lately. lol Thank you again for the tip on the great price! I almost plunked down $350 for the same thing.
