Thread: Need help locating housing gasket seal for pump
    Hey guys. I am having a hard time locating a replacement gasket housing seal on my pump. Here are a couple pics of the equipment and plates. I know it's the housing seal and just need to find one online to purchase so I can replace it. Thanks in advance for your help.
    18x36 Ingound vinyl Liner
    25000 gallons
    Jandy Stealth 2 speed pump
    Jandy 340 Cartridge Filter
    Jandy AE-TI 2500T Heat Pump 118000k btu
    Intermatic PE153 Digital
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Need help locating housing gasket seal for pump
    Give INYO Pool a try, they have lots of that sort of stuff.
    Ok. Thanks mod!
    25000 gallons
