Results 1 to 9 of 9
Thread: Intex Saltwater system
    Apr 2016
    Bellmawr NJ
    106
    Does anyone have experience using these? I'm wondering how effective they are.
    Intex Krystal Clear Saltwater System with E.C.O. (Electrocatalytic Oxidation) for up to 15000-Gallon Above Ground Pools, 110-120V with GFCI Amazon.com : Intex Krystal Clear Saltwater System with E.C.O. (Electrocatalytic Oxidation) for up to 15000-Gallon Above Ground Pools, 110-120V with GFCI : Patio, Lawn Garden
    Intex Ultra Frame 24x52 AGPIntex sand filter #128645HTH 6-way test kitPool was built and filled week of 6/24/16
    Donldson's Avatar
    NW Ohio
    3,212
    Re: Intex Saltwater system
    Works just fine for a very inexpensive no-frills salt water system. Your only options on it is the number of hours you want it to run per 24 hours, that's it. No percentages, no half-hour adjustments, no running at different times of the day, just ultra-basic.
    That ECO system is a copper ionizer on it though. At the very least you want to disconnect the power to that (a very simple process) and possibly remove the copper rods as well (not quite as easy). Don't leave that running on it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Apr 2016
    Bellmawr NJ
    106
    What's wrong with a copper ionizer?
    Donldson's Avatar
    NW Ohio
    3,212
    Since you don't want copper in your water, pretty much everything is wrong with a copper ionizer.
    Apr 2016
    Bellmawr NJ
    106
    I thought the copper kills the algae?
    Donldson's Avatar
    NW Ohio
    3,212
    Proper chlorination kills algae just fine. There is no reason to add a metal to your water that will cause staining and green hair as long as you are properly maintaining your pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Do a search on copper stains (upper right corner) and see all the many, many folks spending lots of time and money tying to remove copper stains from their pools and draining their pools to remove copper from the water. The pool industry is doing a real disservice to people with all these copper products.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Nothing kills Alagae better than Chlorine.
    Essential Links:
    Jun 2015
    Stockholm, Sweden
    261
    Quote Originally Posted by Donldson View Post
    I think you are mistaken. The ECO system does not use copper, unlike the older Intex swg used to. It uses a titanium electrode that should be left connected.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
