Thread: How high CC and TC get during SLAM?
    ka8yiu's Avatar
    Aug 2016
    SW FL
    165
    When slamming, how high can you expect to see your CC and TC get?
    For example, let's say my SLAM level is 12. If I maintain my FC at 12 for several days, can I see my CC and TC rise to 24 or 36 or more, or does the CC start to disappear?
    Kevin
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    30,941
    Re: How high CC and TC get during SLAM?
    You can't "create" chlorine. CC and FC are components of TC and their total is all you can get.
    So, if you start a SLAM by adding 20 FC to your pool, some of that 20 ppm will convert to CC's (usually not more than .5 to 2 ppm) but, in no case will your TC exceed the Total of 20 ppm that you added to begin with. (it will only deplete)
    Please review "The "ABC's of Pool Water Chemistry" up in Pool School....especially the extended info on chlorine, and I think you will have a better understanding of how it all works.
    Chemistry wise, the transaction is quite a bit more complex but TFP strategy works fine following the above ideas.
    domct203's Avatar
    Jun 2015
    CT
    3,892
    Quote Originally Posted by ka8yiu View Post
    Kevin
    Everybody's pool is different, some see very little rise in CC, while others have quite a bit.
    Remember, TC is the sum of FC + CC (CC+FC=TC). If CC's go up, so does TC. BTW- I have never seen a CC that is 2-3X the FC level, but nothing here surprises me anymore LOL.
    During a SLAM, the only thing that needs to be checked is FC. If the water is green, the CC value is useless as it does not effect how to perform the SLAM. Once the water clears, then you can check CC at the OCLT.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    ka8yiu's Avatar
    Aug 2016
    SW FL
    165
    Well, here is my dilemma:
    I did a Jack's Magic copper stain treatment. It has been 4 weeks. According to the instructions, you will get false FC readings for 3-4 weeks. I am still getting the readings.
    Now, for several months, I have had some green in and around the pool, including ON TOP of my solar cover. I have attributed it to dry weather and pollen, as my CC has always been 0. I have only been getting the CC since the treatment.
    The green "pollen" is still around, and may even be getting worse. So, now I am unsure if I am having an algae breakout, or I am still getting false reading. Currently, my CC is about 8, and I am afraid to add too much chlorine to battle algae should that be what the green is or is becoming.
    My water is crystal clear. I could tell heads or tails on a dime in the deep end. But, the green is sticking to the sides in some spots. It comes off easy, brushing and vacuuming up with no problem.
    TF-100 Testing Kit
    ka8yiu's Avatar
    Aug 2016
    SW FL
    165
    Oops, I sent my quick reply too quick.
    "Usually not more than .5 to 2 ppm" answers my question. Since I am getting 8+ CC, I will take it that I am still getting the false readings from the sequestrant in the treatment.
    TF-100 Testing Kit
