Results 1 to 8 of 8
Thread: Not sure if my IG Spa jets should be blowing bubbles or not, how to check?
    Mar 2017
    Sonoma, CA
    41
    This is the next installment of my newbie pool owner questions. I recently purchased a home with and IG pool and attached spa with spillover. When I first started using the spa, in spa mode, none of the jets emitted bubbles. After several uses (days) one of the jets started emitting a small amount of bubbles.
    So I read here about trying to unclog the venturi and I did that by using both a shop vac and an air compressor into the air intake pipe above ground.
    That seemed to really fix the one sputtering jet but none of the other jets is bubbling.
    A couple of pros have seen this and one said that all the jets should be bubbling and the other said that maybe the original builder only put in one bubbling jet and used a variety of other jet types presumably so there would be some variety for various peoples' preferences.
    So how can I determine whether or not the various jets should be bubbling or not?
    There are several types of jets, some with 2 holes that rotate (massaging?), some with one hole that is positionable but doesn't rotate, some with one hole that do rotate on their own. The one bubbling jet is one hole and rotates on it's own.
    I've also tried adjusting the outer control ring to change the pressure on them without any more bubbles.
    Thanks for your help!
    Brad
    Relative newbie pool owner.
    8.5K gal in-ground concrete/plaster pool with connected spa and spillway.
    Pentair Master Temp 400, Pentair Clean and Clear Plus filter, Intelliflo Variable Speed Ultra Energy Efficient Pump,
    Intelli-Touch i7+3, Liquid chlorine and muriatic acid. Taylor FAS-DPD K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Not sure if my IG Spa jets should be blowing bubbles or not, how to check?
    If the jets have venturis, they should be bubbling.
    Those are actually the exterior fitting for the jet. The jet nozzle lies behind those fittings and can be remove to flush out the lines. Trying to blow the debris backwards may not work very well. You need to remove the exterior fittings and then the jet nozzle using a long extension sock wrench. If you run the spa without the nozzles it may clear the debris.
    Mark
    Mar 2017
    Sonoma, CA
    41
    Quote Originally Posted by mas985 View Post
    Thanks very much. Sorry I didn’t see your response earlier.
    If I remove the exterior fitting, how would I tell if there is a venturi or not, would I see a small narrowed opening vs a fully-open pipe?
    Probably a dumb question, but can I do the steps you outline without first draining the spa below the jets?
    Thanks again
    mas985's Avatar
    Pleasanton, CA
    11,987
    It is a lot harder to take out the jets without draining the spa. But keep in mind you can drain the spa into the pool so you don't lose any water. You just have to put the return valve to the pool and suction to the spa.
    Mark
    Apr 2015
    tucson, arizona
    1,314
    Sounds like you have the waterway poly jets, you need to turn counterclockwise till it stops and the jet will have full pressure. If you keep turning same way you will unscrew internal fitting out of wall, where you can then turn on and hopefully clean any debri inside. Check each jet the same way and make sure by holding jet in hand and turning the face you can see the end opening and closing. Instruction Manuals
    Mar 2017
    Sonoma, CA
    41
    Thanks. It looks like if I remove the exterior housing and look inside, if there's a venturi I should see something like the bottom right connection in this picture. Is that correct?
    https://www.mypoolyard.com/images_pd...e_210_3330.jpg
    mas985's Avatar
    Pleasanton, CA
    11,987
    Yes, if you have that style jet.
    Mark
    Mar 2017
    Sonoma, CA
    41
    I got them all working! All I did was remove the exterior housing on all of them and run the spa with jets and apparently unclogged them. Great to see all 6 jets working.
    Thanks everyone for your help!
    Brad
