Results 1 to 10 of 10
Thread: Plaster (Marble Dusting) & Plumbing Renovation cost?
    Apr 2017
    Nissequogue
    2
    Hi All!
    Last Oct. we bought a house with a gunite pool located in St. James, N.Y on Long Island.
    The pool was built in 1978 and the plaster and all the herringbone pavers are in need of a redo. Some have said that if I'm removing all of the pavers, now is the time to redo the plumbing aspects of the pool. I do agree. I've gotten a quote from a family owned pool place and think it's a bit high compared to some of the quotes I've seen online...I would appreciate some thoughts. The pool is 20x40 with 4' shallow/8' Deep. Thank you!
    Here is the breakdown:
    Coping & Tile Removal - $1000.00
    Acid Wash Pool - $1400.00
    Bluestone coping - $6500.00
    Tile - $3600.00
    Marble Dust/Plaster - $8400.00
    Skimmers (boxes & Lines) - $3500.00
    Returns (returns & Lines) - $2500.00
    Main Drain (pool side to filter) $1000.00
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: Plaster (Marble Dusting) & Plumbing Renovation cost?
    Welcome to TFP
    I have no specific recommendations for you but other experts will be along soon to help out. Most likely, to compare prices and know if you're getting a good deal, then you need to get multiple quotes. It's the only way to sort out pricing since it is all very regional. And given where you live, in-ground gunite pools are very rare. I suspect when the original owners put it in, they had A LOT of money to do so (in today's dollars).
    One other reason I wanted to post - I grew up in East Setauket not too far from where you live. All of my family has since moved away from LI, but it's always fun to see new people from LI show up on the forum. I spent many, many summers as a kid playing on West Meadow beach and the rocky North Shore. Nissequogue is a beautiful area to live in.
    Good luck with the renovation!
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,916
    I agree with Matt that your best bet is to get as many quotes as possible from your area. It really depends on the area.
    I would love to see what it looks like now.
    Kim
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Re: Plaster (Marble Dusting) &amp; Plumbing Renovation cost?
    When we started getting quotes to remodel our pool I kept joking "No, you're confused ... we already HAVE a pool, we just need to update it". And my husband had already updated all of our equipment. It's expensive; probably why people fill in their pools instead of fix them up.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Mar 2017
    Lake Forest, CA
    16
    I just paid about that same amount and had less work done. I imagine CA and NY rates are pretty similar.
    Mar 2017
    Lake Forest, CA
    16
    To be more comparable and clear on my comment - the tile price is pretty spot in to mine if just a regular porcelain. I went with a cheaper stone so there is a bit of price difference there. I don't know about marble dust but I went with quartz and my plaster quartz is a bit less as well. Overall, for the work that was done which is similar to yours (tile, coping and plaster), I was about $6k cheaper. But it seems like you are getting some higher end finishes.
    I would ask them to price out sandblasting the plaster down to the original gunite. We paid about what you were quoted for acid wash. Two advantages - avoids risk of missing weak or loose spots in existing plaster and it enables you to get a visual check on the gunite.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Apr 2017
    Nissequogue
    2
    Thanks for the responses. I have another company coming today. I will update, and when it's all over I will be sure to post pics!
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    570
    It seems a bit high but not way off - for this price I would expect very nice high quality work and expensive materials.
    What I did not see was any new equipment - pump, filter, chlorinator, automation, LED lights
    I also DO NOT understand why they would acid wash when they are going to replaster. The surface needs to be roughed up and any loose plaster removed before replaster. Also a bonding agent is used if you are doing plaster over plaster. I would expect to get sandblasting for the surface prep.
    For your quote of plaster I would expect you could get a pebble finish.
    But you are in Long Island or the high rent district.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
