Thread: Algaecide vs shock?
    Sr. Notso's Avatar
    Apr 2017
    hemet, ca
    2
    Algaecide vs shock?
    Okay, so pool supply houses sell overpriced low active ingredient (copper) algaecide. Any comments on using Cutrine Plus?
    Sr. Notso
    Hemet, CA
    25 yr. old plastered 20x40 Lagoon style play pool, 3.5'-5'-3.5'. Epoxied and repainted. New Pentair Quad D.E. 60sf and Raypak Variable Speed Pool Pump 1.65 THP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Algaecide vs shock?
    Welcome to TFP!
    I've never heard of that. Things that have CU in the name usually contain copper. Copper builds up and stains pools and people and dogs. I have been able to maintain my pool fine for five years without cutrine plus, I'm sure you can too. All you need are these, Pool School - Recommended Pool Chemicals
    Donldson's Avatar
    NW Ohio
    3,219
    Isn't that an algaecide for ponds?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    30,946
    Yeah, cutrine is an aquacide and is LOADED with copper.
    Sr. Notso, why would you even consider using it?
    That might be akin to using cattle spray for a mosquito bite!
    It's too easy to find alternative weapons than to use copper in ANY pool.
