Results 1 to 9 of 9
Thread: Where should I dump my test-kit water?
    Mar 2017
    Fullerton, CA
    17
    I might be pushing the theory of there being no such thing as a dumb question here, but is there a "right" place to dump my tested pool water once I have my numbers? I've been dumping it on the deck, on the theory that concrete is tough and not chemically reactive, but then I don't know what the test reagents are. Am I killing my concrete?
    Would I be better off dumping it on the lawn and maybe killing those darn dandelions...?
    ~22,000 gallon IG plaster pool with spillover spa | Hayward Progrid DE filter | 1.5 HP single-speed Pentair WhisperFlo pump | Poolvergnuegen The Pool Cleaner 4-Wheel Cleaner | Taylor K-2006 test kit
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Re: Where should I dump my test-kit water?
    In the small amounts used, those test reagents will not hurt the lawn. When I test outside, that's where I dump. If I'm inside, it goes down the drain.
    While it won't hurt the concrete, i don't know if it might stain over time.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    I dump mine in the flower bed. The flowers don't seem to mind at all.
    Divin Dave,
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Huh... I've been dumping it in the pool... never gave it a thought.
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Quote Originally Posted by cjpwalker View Post
    That's the last place you should be dumping them. Just dump them out onto the lawn.
    Dom - TFP Guide
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Never dump your test samples in the pool. Especially if you do a Salt test with the yellow reagent. It's made from Chromate...so not good. Either way, no samples dumped back into the pool!
    Essential Links:
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Huh... didn't think it was that big of a deal. We're talking parts-per-billion... Thanks, though, I'll start throwing it in the yard.
    domct203's Avatar
    Jun 2015
    CT
    3,898
    I look at it this way, my family is swimming in this pool, the little ones are more than likely swallowing water.
    I'm not putting anything in this pool that does not have to be in it, period.
    Dom - TFP Guide
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    I know my white kitchen sink doesn't like one of the chemicals, and I don't know which one. I get stains that I have to bleach off every time. I sure do hear it from the wife too!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
