Results 1 to 7 of 7
Thread: Chemistry addition vs water level
    Jul 2016
    Valparaiso, IN
    27
    The sun is shining and my pool is open in northwest Indiana!
    We closed late and have opened early. Water looks pretty much perfect.
    My sweet spot for the water level is the second screw head up from the bottom on the skimmer mouth. The skimmer will take in water 2" below and almost 2" above that point but that's the magic spot I settled on.
    My question is this..... Since I set my "gallons" to be 17,100 (27' X 46") in pool math, what affect does less or more water make to the health of the water? Those 2 inches amount to several hundred gallons. When it comes to gallons in Pool Math, I usually set it and forget it.
    (I do manage the water in the pool, but not usually until it gets to either extreme).
    Edit......For whatever reason I had been using 17,100. But 27'x46" is actually 16,500.
    Aqua Leader 27' (54") 17,100 gallon, Hayward SW 256T sand filter, Hayward 2 hp 2-speed pump, water testing with a TF-100.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Chemistry addition vs water level
    Just calculate your gallons to the height you keep your water level at. Only one that matters! Either add or subtract those several hundred gallons when you calculate additives.
    Jul 2016
    Valparaiso, IN
    27
    Ok, maybe a better question....how often do you add water to your pool, even if the water level is appropriate for the skimmer level, but NOT the calculation you entered into pool math?
    Jul 2015
    Central Valley CA
    1,166
    Even a 1000 gallon swing should only change your bleach additions by an ounce or so, when I was manually adding I am sure I was +/- a couple of ounces each time as I was not using a measuring cup just graduated approximations on my bleach bottle. I don't think you will have a problem, I should however admit I have an auto fill.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2010
    East Texas
    10,152
    Yep, you're pretty much into the range of insignificance there.
    Jul 2016
    Valparaiso, IN
    27
    Copy copy....many thanks
    Aug 2016
    Riverside, CA
    378
    We're talking parts per MILLION in 10's of thousands of gallons. A couple hundred gallons isn't going ti make a difference at all.
