Thread: 1st time opening with a heater
    We are in NJ so the weather is still up and down. Supposed to be in the 70's this week.
    I know that SWG's typicall dont produce under 60.
    Is it ok to open the pool early if i am using the heater to bring up the temlerature?
    Also should i run it 1st for 12 hours or so prior to tunring on the SWG? I want to make sure the salt levels are good to go
    Thanks!
    Tom
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: 1st time opening with a heater
    Yes, that is fine. You can use bleach/liquid chlorine to raise FC until you get the SWG up and running.
    Great
    Thanks!
