Thread: Replace 2 in. Rigid pvc with flex pvc?
    Apr 2017
    Central Florida
    2
    Hello,
    I would like to replace my 2 in. solar panel rigid return line with flexible 2 in. pvc. There are various manufacturers - Sioux chief. Hydromaxx, flexpvc. They can handle working pressures from 60 to 100 psi.
    First off, is this a good idea? Has anyone ever used flex pvc in a solar installation?
    This is for a 12 panel fafco system.
    Thanks
    20,000 Inground
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Re: Replace 2 in. Rigid pvc with flex pvc?
    Just curious, but why replace the rigid?
    Whenever I see flex pvc installations I cringe...they seem more susceptible to caving in and
    other damaging situations than rigid...but I could be completely wrong.
    Dolphin E10 Cleaning Robot.
    Apr 2017
    Central Florida
    2
    Replacing broken couplings, elbows, etc. is more troubling with rigid. With the flexible pvc I would only have 2 couplings on the roof instead of the 5 I have now.
    Also, I'm not too concerned about the flexible collapsing as it too is sch. 40.
    20,000 Inground
