Thread: Skimmer Leak and Suction Side Vacuum
    Jul 2016
    Florida
    34
    I had a leak detection company tell me that I had a leak at the skimmer pipe connection (somewhere at the the pipe thread connection) and he tried to fix it with some two part epoxy. We'll see if it holds. He told me to stop using my suction side vacuum at the skimmer connection because it will just aggravate the problem. I don't disagree with him. However, I'd still like to use my vacuum. Since my pool equipment is located very close to my pool, would there be anything wrong with putting a tee and valve off one of my pump suction lines and use a flex hose direct from the pump to my vacuum? Any other ideas / suggestions?
    Thanks
    Dennis
    St, Augustine, FL / Covered Screen Enclosure
    1982 IG plaster/pebble - 18K gallon city water, Hayward C900 Cartridge Filter, Single Speed Pump 1.5hp
    Testing with TFT-100, Treated with Liquid Chlorine, Muriatic Acid, and Baking Soda
    30,950
    Re: Skimmer Leak and Suction Side Vacuum
    You maight have to rig a little better connector than flex-hose but your idea is solid. With a little thought it will work.
    If it's in the budget. a complete fix requiring no thought at all but rather some significant money is to buy a robot.
    Jul 2016
    Florida
    34
    Thanks for your feedback. What's the downside to the flex hose? Other than it's not a clean solution. Too much pressure loss with the corrugations?
