Results 1 to 7 of 7
Thread: Is this PVC?
    Jun 2016
    Webster Groves, MO
    14
    Is this PVC?
    I'm re-plumbing the equipment pad of a pool I inherited a few years ago. Pulled up the deck boards to get to more of the piping and found a connection I didn't understand. What I would have assumed was PVC pipe coming from the pool connects to what I know to be PVC pipe heading to the pad, but with steel hose clamps instead of glue.
    Is the black pipe PVC? If not what is it? It is hard pipe.
    35k gal IG plaster (25 x 45ft), 3HP Intelliflo FX, Pentair Quad DE 100, Intellichlor IC60 SWG, Polaris 280 w/ PB4 booster pump, Raypak P-R406A
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Is this PVC?
    That is most likely polyethylene pipe. No glue will stick to it for any length of time, hence the barb and clamps.
    Jun 2016
    Webster Groves, MO
    14
    Re: Is this PVC?
    1. Why would they have used that? (It looks like it is used for the return line and the main drain. The two skimmers are Sch 80 PVC)
    2. Is it bad? Not that I can do anything about it, just want to learn more about it.
    3. When I cut it back and make a new connection to PVC, is replicating the connection that is there now still the best way to do it?
    30,946
    Re: Is this PVC?
    What is it used for? That'll help answer some of the questions. Is it pressurized? Is it a drain pipe?
    If you are not sure, try a pic that includes what it is hooked up to.
    Jun 2016
    Webster Groves, MO
    14
    Re: Is this PVC?
    In the second picture from left to right is Skimmer 1, Main Drain, Skimmer 2, Return to eyeballs. The skimmer pipes transition from PVC 40 to PVC 80 out of frame of the picture. The main drain and the return both use this black pipe with the steel hose clamps.
    In the first picture you can see where they all turn 90 up into then the union valves for each that are accessible from the pad.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Is this PVC?
    There is nothing wrong with poly pipe. It's very durable and last for a very long time. Most residential wells are plumbed with poly pipe.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2013
    Sacramento, CA
    2,769
    Re: Is this PVC?
    Polly pipe has issues with the connections rusting out or corroding. But is is better for low temperature applications. Poly will handle freezing and frosts better than PVC. Generally you don't want to run either unprotected above ground like yours are.
